C4 third brake light on C3 coming soon...
C4 Brake light on C3
Because I wanted it trick part was making studs to mount the light .... roll bar main hoop is right under so M6x1.0 bolts wouldn't work... so i cut off the heads and turned down and threaded the other end 1/4-20 and just so you know BP891 bulbs (4) are 5.99 each :O
the light is off an 86
So that's a C4's. The turd I bought had one on it, didn't know it was Corvette's.
its the White wire :bounce::twitch:
