Toyota 4runner booster and master
1Michel
Saint Joseph du lac, Québec
Just curious, I was asked if this booster and master cyl would do the job on a C3
It comes from a Toyota 4 Runner wich is I would guess heavyer than the C3.
Would that do the job?
From the looks of it, the master might hit the hood. If it does clear, and as long as the bore size is correct, (Factory power brake is 1.125" IIRC) I dont see why it wouldnt work... but why use the 4Runner stuff? Use a C5 master if you want something lighter and more modern looking. Bolts right up, just needs some adapter fittings
Because I had one in the garage, and I was curious, Bore size was a bit smaller anyway
But hey , free parts.
friend of mine took his truck in and we dismanteled it, the motor and tranny was shot and before he send it to wreck I took a bunch of parts off of it.
Since it was in the shop, I was just curious.
I took the door latches wiper motor, hand brake handle and cables.
He also had a complete brake system on it, rotors, master etc calipers ( who strangely looks similar to C3 binders) wheels and tires for his newer truck witch was the same year and color.
I was just curious.
truck is gone and crushed now lol.
