*Vette Running Lean, Then No Start*
AGVI
Mississauga, Ontario
I recently installed a 406 and it was popping through the exhaust. The headlights and other vacuum accessories were running through the carb. I moved the vacuum accessories to run off the intake and the popping went away.
I went on a short trip (5 miles) the other day and it started hesitating and wanted to stall. I shut it down and it wouldn't start again.
What should I look at first? Ignition problems?
Let me know if you need any other info on the car.
thanks :noob:
That is a very hot cam that you have there. I wouldn't be surprised if you fouled the spark plugs, I bet low rpm cruising is not all that great with that cam.
I used to run the edelbrock performer rpm cam with too low CR, plugs lasted 60 miles or so... previous owner installed the cam, took me a while to figure it out... the plugs were fine as long as I kept the engine at 3000+ rpm..... :eek:
It could also be a spark plug wire burnt on the header pipe.... I'm sure it's something simple.... keep us updated :thumbs:
UPDATE: It was a burn't wire that leads to the MSD ignition. Hard to find, but an easy fix. Vette runs great again.
Glad you found it and it wasn't a big problem.
If I want to keep my BB running perfectly, I'd have to change plugs everytime I drive it. The plugs I put in for the Bird I tour are dead now. They look FINE, but it craps out about 5k.. New set of plugs and I'm back to the rev limiter.
HUMMMM....Wish I had YOUR gas money....
I hit you for a loan next time I C U.....
:crutches::crutches::devil:
