  #1
Old 04-05-2008, 01:27 PM
TimAT's Avatar
TimAT TimAT is offline
Cruise-In Bird-Run 1 Veteran
My Photos: (60)
Default Are you troubled?
By bad grounds? We've all had problems with poor grounds on Corvettes, tailights, headlights, gauges, no start, you name it. There is a little tool that may help. Once you find where the bad ground is, it's time to clean it up. Try this:
Not maybe as quick as grabbing some sandpaper and digging the rust off, but a lot neater and once you have one in your toybox, lots faster too.
Why is it that all instruments searching for intelligent life are pointed away from the Earth?
  #2
Old 04-05-2008, 07:47 PM
big2bird's Avatar
big2bird big2bird is offline
United States | Charter Member
Founder Bird-Run
Cruise-In Bird-Run 2 Veteran
My Photos: (342)
I can't tell you guys how important good ground contacts are. Too many guys powder coat, POR15, and get so obsessed with rust, they miss the point that the entire chasis is 1/2 of the cars electrical circuit.
Wherever you have a ground cable/and or strap, clean it to bare, and install a star washer. Do NOT reuse one. Unlike spring typr lockwashers, star washers crush, and are actually only good for one use. Get new ones. They are cheap. If your concerned about rust, smear grease on it.
1 ohm resistance does not sound like alot, but with 12 volts, it is.
I can make your dizzy. Really, I can.
  #3
Old 04-06-2008, 02:00 AM
SMYDA's Avatar
SMYDA SMYDA is offline
United States | Knuckle Dragger
My Photos: (0)
Quote:
Originally Posted by big2bird View Post
I can't tell you guys how important good ground contacts are. Too many guys powder coat, POR15, and get so obsessed with rust, they miss the point that the entire chassis is 1/2 of the cars electrical circuit.
Wherever you have a ground cable/and or strap, clean it to bare, and install a star washer. Do NOT reuse one. Unlike spring type lock washers, star washers crush, and are actually only good for one use. Get new ones. They are cheap. If your concerned about rust, smear grease on it.
1 ohm resistance does not sound like a lot, but with 12 volts, it is.
Thanks for that tip...... I was unaware of that........of all the classes I've been
to, that has never been addressed. I've always reinstalled the original.
I'll have our parts guy order a batch Monday.
  #4
Old 04-07-2008, 08:19 PM
BRUTAL64's Avatar
BRUTAL64 BRUTAL64 is offline
United States Outlying Islands | Neanderthal
My Photos: (4)
Actually, I've been of the mind on a VETTE; You can never have TOO many grounds.
"If it is left to the present Congress, we’ll get the best thinking of the eco-nazis, the safety nazis, the California Air Resources Board, Speaker of the House Nancy Pelosi, and the Biosphere 2 people. For the good of the nation and its citizens, these clowns should be kept as far from our automobiles as is politically possible."
David E. Davis Jr.
64 Vette Roadster 400 ci- Dual Quads
70 Thunderbird 429 ci
48 Harley Panhead 76 ci
  #5
Old 04-07-2008, 08:23 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
I can't tell you guys how important good ground IS
There, fixed it 4 U.....
as if anyone in Ca.L/A-Hollyweird should know....good ground is at a premium....earthquakes, midslides, fires, winds....
GENE (ready for the hurry cain comment).....
  #6
Old 04-07-2008, 08:53 PM
Belgian1979vette's Avatar
Belgium | Addict
My Photos: (104)
Good tip, i powdercoated everything to.
