69427
Got a question. As we all know, the older tach drive distributors are iron housings, while the later points housings are aluminum. I'd like to somehow transplant my (heavy!) distributor's internals into an aluminum housing. I've heard that there are some tach drive HEI clones out there. Are they using custom shaft parts, or "old" type shaft internals in the HEI shaped housing? I'm just trying to figure out if I could modify one of these HEI clones by cutting and welding on a small cap base, or just weld the side gear holder "lump" onto an aluminum housing points distributor.
Thoughts or advice?
Thanks,
Mike
Thoughts or advice?
Thanks,
Mike
