  #261
Old 09-11-2019, 12:56 AM
69427's Avatar
69427 69427 is offline
My Photos: (2)
Quote:
Originally Posted by phantomjock View Post
When you are ready to cut the product after layed up and cured, I used a tile wet saw. [Harbor Freight - Naturally.]
The water helps keep the dust (bad for you and your lungs) way down. The wet swarf is still something to contend with however.
Looking forward to the results.
Nice work!
Damn, I had to google swarf.
For as many decades as I've swept up that stuff, i'm embarrassed that I didn't know the official name for it.
  #262
Old 09-11-2019, 10:41 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (308)
I had to Google peel ply!
  #263
Old 09-12-2019, 01:25 AM
vette427sbc's Avatar
My Photos: (107)
Heres what Ive got so far for the rad exit...
Both sides will be flanged, to mount to the rad, and to meet up with the hood section. I didnt want the duct to go all the way to the hood so that I can do basic checkups on the belts, oil pump, power steering, etc without removing the duct every time. The hood will have the rest of the duct molded in so that it just lifts out of the way when you open the hood.
(mixed the bondo a little too hot!)
And the passenger side gill...
This is a weird shape and Im having a hard time getting this to cleanly attach to the wheel tub. It will be worth it in the end... a view of a 335 tire in a carbon duct through the side gill! Off to buy some thicker foam board...
Chris
AutoWorks Middletown NJ
@autoworksnj
  #264
Old 09-12-2019, 03:20 AM
mfain's Avatar
mfain mfain is offline
My Photos: (6)
Very nice!! A question - do you have a surge tank? Looks like your radiator cap is well below the water level in the intake, so won't you need a higher fill point to purge the air?
Pappy
Pappy
  #265
Old 09-16-2019, 10:33 PM
My Photos: (107)
Quote:
Pappy
Currently, no... I havent gotten that far yet; but I was hoping to not have to run one. I use a vacuum filling system, so I was going to see how that works to fill it sans-air. I bought an inline radiator cap that I may put on the upper hose somewhere if I cant defy gravity with the vacuum fill.
  #266
Old 09-24-2019, 02:00 AM
My Photos: (107)
ProLite column from Iditit showed up this weekend... it is exactly what I wanted. Steering wheel, firewall bearing support, quick release hub and the upper u-joint is 10lbs... 11.5 lighter! (I think my stock non tilt one was 21.5 lbs)
I have to send it back to have them “tweak” a few things, but overall I’m very happy with it.
  #267
Old 09-24-2019, 09:35 AM
BBShark's Avatar
My Photos: (308)
Is that a swivel bushing on the plate where the column comes through the firewall?
  #268
Old 09-24-2019, 02:49 PM
SuperBuickGuy's Avatar
My Photos: (0)
you bought the one for a Camaro?
  #269
Old 09-24-2019, 03:00 PM
My Photos: (107)
BBShark- Yes, its quite beefy too. Looks like a quality piece.
SBG- No, this is specific for a vette, I gave ididit the dimensions for a corvette so its a custom build. Im giving them feedback on dimensions and fitment so they can have the C3 as an option down the road.
  #270
Old 09-24-2019, 04:48 PM
My Photos: (0)
nice
