rtj
- Joined
- Nov 5, 2011
- Messages
- 2,968
Just got this in an email:
The C2 and C3 Corvette differentials come from the factory with a 17-spline inner flange yoke that can be prone to failure. Our solution is to upgrade the rear by modifying a stock Corvette posi-traction carrier with 30-spline side gears and adding a one-piece 300M 30-spline inner flange yoke shaft that eliminates the bolt-on flange yoke.
300M forging, double heat treated and shot peened
Increased strength with 30-tooth involute profile spline
Removable billet u-joint caps with studs and ARP® nuts
Uses standard GM c-clip to retain yoke shafts
100% machined and produced in house, in the USA
Part Number 50245 - C2/C3 Corvette Axles, Inner Yoke Shaft (stock differential)
https://www.markwilliams.com/50245....il&utm_term=0_1a187180f2-de42a852c8-426849805
To upgrade the stock Corvette rear to use our 30-spline Inner Yoke Shafts, the posi-traction is modified by slightly increasing the bore size and using a 30-spline axle gear that is common to the 12-bolt GM passenger car posi-traction units. A simple machining operation to the posi-traction case is required. Instructions are provided for the modifications, but new, modified Eaton™ posi-traction units, with the 30-spline side gears, are available to save you time and assure the job is done right.
Part Number 19670-MOD
https://www.markwilliams.com/19670-mod.html
Comments?
Comments?
