Go Back   VetteMOD.com > VetteMOD Workshop > Shop, Tools and Equipment
  #11
Old 10-10-2018, 12:18 PM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
Kind of neat. Could add an XY table and computer control. Been thinking of getting a plasma cutter.
  #12
Old 10-27-2018, 01:05 PM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
Quote:
Ordered this off amazon for $60.
“DIY Ball Turning Attachment for Lathes / Radius Turn Ball up to 38 mm...”
It took 5 weeks for delivery, but other than having to run a tap into the threaded handle hole, it looks like a good deal. It even came with a carbide insert. And, has a smooth ball bearing movement.
Now to STOP doing home improvements and get back on the cars.
  #13
Old 11-11-2018, 03:12 PM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
I got a box of end mills really cheap when buying a rotary table. Sprayed them with wd40 and they sat a few years. Started going through them this summer and some are dull, but it was a bargain in retrospect.
  #14
Old 03-14-2019, 12:49 AM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
I like the drill and sanders. With a coupon you can usually get an HF angle grinder for $10.
  #15
Old 04-08-2019, 12:22 AM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
Too lazy to start a new thread, but thought these were cool.
  #16
Old 05-03-2019, 11:17 AM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
Shows a bunch of custom auto parts for his FFR build.
  #17
Old 05-03-2019, 01:56 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (271)
Never seen anyone drape a vice/table on a mill. Sure would make cleanup easier.
  #18
Old 05-03-2019, 03:50 PM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
Quote:
Until it wraps up in the spindle and drags your hand in!
Funny, I saw that and thought it would keep things clean too and then said I’d never do that. Plus, I always use oil, so that material would be a mess. I just vacuum now and then.
But, when I was a kid, I’ve seen guys blow off being told to cut their long hair. We had big rotating “cat heads” at head height. Some people like living dangerously.
