JeffP1167
Anyone done it and can offer pics or advice to make this go smoothly. I'm sure the rear shocks won't be to bad but I have never done a coilover strut before.
The rears are super easy. First remove the interior stuff to get to the top bolt, impact gun quickly loosens it. Then jack up the rear, undo the lower bolt and pull them out.
The front is a different animal. You have to take out the entire strut and one tio bolt is partially obscured by the master cylinder.
Undo all 4 top ones, 2 are nuts on studs, 2 are bolts. Jack up the front of the car and undo the sway bar end links and then put a jack under the ball joint. Remove caliper and move out of the way, remove rotor too. Put some load on it, whack the spindle w 2 hammers to crack the bond between the BJ and spindle, remove but and carefully lower jack. Remove upper ball joint nut. There is some residual pressure there. When the pressure is off take the 2 bolts out of the little bar that secures the shock to the lower arm, move the shock outboard and pull the strut out with the upper a arm.
The whole unit comes out as 1 piece.
You will not have to remove the upepr arm, it pulls off the studs. Keep that rubber grommet and hope your nut/thread on the strut is not all buggered up. If you throw the strut away you can simply cut the top off. First however get some outside spring compressors and pull the spring together, do not remove the upper nut before...it will come flying apart.
When putting it all back together, make sure you remove all rust scale from the arm and the pocket where the spring sits, also from the inner fender. If there is scale rust or debris there the stuff will not seat back properly and it will make a rattling noise.
You also need the spring compressor to install the spring on the new strut.
he already has the v6 springs as his car came equipped with those
is the suspension different on the 93-97 different than on the 98+ models ? Thought it was all the same, the V6 rides a lot softer/smoother than the V8 - different springs and sway bars... I think the shocks are the same on V6and V8 ... the SS is another animal, those came with the SLP package if I remember correctly...
I have Monroe shocks in my Mustang, ride is quiet harsh but it's lowered too....
