Go Back   VetteMOD.com > VetteMOD Workshop > Rebuilding Techniques
  #21
Old 05-01-2009, 07:37 PM
cajos1968's Avatar
cajos1968 cajos1968 is offline
Netherlands | Addict
My Photos: (0)
I'm already following it!! Mike's kit is here next week. Swapped red paint for red powder coat (ral 3001) and will sand/polish the two caliper halves where they meet with some 600 grit on a flat marble surface.
Gas, Grass or Ass no one rides for free!
  #22
Old 05-03-2009, 01:28 PM
Stpman's Avatar
Stpman Stpman is offline
Canada | Addict
My Photos: (0)
Great write up I have to do mine soon so I will refer back often, I have one question. Is it ok to blast the caliper halves to clean them?
Steve
  #23
Old 05-03-2009, 09:15 PM
V-Twin's Avatar
V-Twin V-Twin is offline
My Photos: (139)
Just blast them with the pistons and seals installed, never had a problem with that. When you pull it all apart you can clean out all the sand with compressed air and check againafter cleaning the caliper halves (blow out the fluid passages). The rough finish on the piston won't hurt, the seal will be replaced anyway.
  #24
Old 05-03-2009, 11:14 PM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Duct tape in the bore and the old dust seal is good enough to protect it during sandblasting - I sprayed brake cleaner thru all holes and blew air thru there to make sure it's all clean after blasting .... unfortunately most if not all of these old calipers need to be blasted, brake cleaner and wire brush just doesn't get it clean....
Link to my garage:
  #25
Old 05-03-2009, 11:53 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Quote:
Yeh, but one quick drive on this sandbar, and i'ts full of sand again....
couple trips up/down I 95 and they are sandblasted....
  #26
Old 05-09-2009, 08:03 AM
cajos1968's Avatar
My Photos: (0)
Can I add a remark?
When placing the pistons with the o-ring and seals lube them with the braking liquid (DOT X).
And a question:
Do you place the springs back?
  #27
Old 05-09-2009, 11:23 AM
MYBAD79's Avatar
My Photos: (882)
Yes, I used brake fluid to lube the rubber - makes it a lot easier to push the pistons in the bore.
I did not use the springs. The O-rings are so much tighter that the spring would most likely not push the pistons anyways.
  #28
Old 08-27-2009, 12:09 AM
Arthur Brown Arthur Brown is offline
My Photos: (1)
It's been a few months, how many miles did you drive with the "new" brakes and are they performing to your satisfaction?
  #29
Old 09-04-2009, 01:15 AM
MYBAD79's Avatar
My Photos: (882)
Quote:
I've put approximately 500 miles on the car since I did the brakes....my brakes have never been this good, it's definitely worth the money ($140 shipped)... I have only done the front so far, the rear still needs to be done. I am lazy and it's too hot to do anything right now.... I'm sure the Wilwood calipers are better but they also cost a lot more, the O-rings and semi metallic pads are a inexpensive mod that can be done at home, no "special tools" required other than a pipe or bearing race driver to drive the dust seals in.... way better than what I had before (AutoZone calipers with lip seals).
