BangkokDean
Hi,
I recently installed a rebuilt 700R4 trans(http://vettemod.com/forum/showthread.php?t=8983) and it seams to shift OK, but when checking the pressure it is a constant 200 psi even when revving,in gear or moving the TV cable. So I tried Google and found 20 pages on constant pressure after market valve bodies info, I have a stock VB.
Does any one know what the pressures should be with the stock 700R4 trans?
I had used the TV Made Ez - Spring in my stock VB.
