Go Back   VetteMOD.com > VetteMOD General Discussion > Projects
Reply
Thread Tools
  #1051
Old 06-17-2016, 01:45 PM
bobs77vet's Avatar
bobs77vet bobs77vet is offline
United States | Addict
My Photos: (2)
Default
so now i move to the door openings....this gives me the front window and door openings done which allows me to put the vinyl on the scuttle, the mirror and the demister vents and then install the dash board and install the front window....the rear panel can be the last thing i glue down. now all i am waiting on is for my distributor to finish getting rebuilt by Jeff
  #1052
Old 06-17-2016, 04:01 PM
SuperBuickGuy's Avatar
SuperBuickGuy SuperBuickGuy is offline
My Photos: (0)
Talking
I think we may be done about the same time.... fortunately, since mine is a soft top, I don't 'have' to have it done before beating it like the cross-bred, red-headed stepchild it is
[/url]
  #1053
Old 06-19-2016, 10:54 PM
bobs77vet's Avatar
My Photos: (2)
Default
oh yeah thats sweeeeeeeeeeeeeet, i saw and old style dune buggy that would be fun too
on a coupe the scuttle vinyl and mirror and demister vents have to go in before the windshield and the pillars have to be wrapped with headliner material before the door opening panel goes on.
remove clamps and trim material where necessary
wrap pillar glue both sides
wrap around edge and glue and clamp
this is how i glued it folded it over
install mirror and cut out demister vents
all stainless steel fasteners
lets see about the windshield gasket.....35 yrs old new and never installed
i have to clean off the gasket and lets start the stretch of the old gasket
  #1054
Old 06-21-2016, 12:42 AM
bobs77vet's Avatar
My Photos: (2)
Default
my rope measurement says i need 119" of circular gasket length, which incidentally is exactly what i have its just under tension and not relaxed lets see what a couple of days of Virginia sun does to loosen it up
  #1055
Old 06-22-2016, 07:10 PM
bobs77vet's Avatar
My Photos: (2)
Default
what a PITA this is turning into.....
the gasket does not want to stretch over the glass in a one person work environment.....tonight I might put 3 other sets of hands on this
tried for over an hour and it just did not work. there is significant difference between my new rear window seal and the NOS front window seal in there flexibility and stretchability
and now I am stretching the rear glass one also...goal this weekend all front/rear glass and dashboard in..
  #1056
Old 06-23-2016, 10:09 AM
My Photos: (0)
Default
I bought a brand new FJ40 windshield seal. Couldn't use it because it was too soft and the wrong size.... don't know what to tell you about why the stock one won't fit, though. The solution for mine was generic rubber seals.
  #1057
Old 06-23-2016, 07:46 PM
Sam Cogley's Avatar
Sam Cogley Sam Cogley is offline
My Photos: (0)
Default
Does Steele sell a windshield seal for the MGA?
  #1058
Old 06-24-2016, 02:26 PM
bobs77vet's Avatar
My Photos: (2)
Default
I WIN!!!!!!!!!!!!!!!!!
different ball game today.....two of us one extremely stronger then the other....little joe: 23yrs old. 6'3 210+ lacrosse player and old soft me....i can tell you we needed the muscle
the stretch did the trick.....put the one end side on first taped it down so it would slip off and then moved to the other end, it was obvious from the start the gasket was more flexible. it still was a chore and we tried putting the rope in the glass slot so when we rolled the gasket over the glass from the bottom we could pull it out....that and the Popsicle sticks from Michaels did the trick. i am not sure the rope gave us anything but once or twice it clearly provided a benefit.once we got the second end done we taped it down an moved to the long sides....about 30 minutes of pretty intense work. mostly cause the old gasket was so stiff. the stiffness is dramatically different then
the new gasket for the rear window
I am going to let it get use to the window for a while in the sun and then as soon as i get another helper it will get installed today.....
  #1059
Old 06-24-2016, 11:52 PM
bobs77vet's Avatar
My Photos: (2)
Default
well it is what it is......read on
finished headliner install
glue top first then side panel
glue side panel
next is the back panel
photo of glued bottom
seam
install parcel shelf to act as a "clamp"
  #1060
Old 06-25-2016, 12:10 AM
bobs77vet's Avatar
My Photos: (2)
Default
win some lose some.....
add the string for seating the gasket over the window flange
pull out rope and it seats itself well sort of...
work both sides evenly
freaking looks awesome
not so shabby if i must say so myself
well except for that.....
I never should have tried to use the old gasket or maybe the dead blow hammer either, oh well $185 for the windshield $80 for the gasket
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
