Go Back   VetteMOD.com > VetteMOD General Discussion > Projects
Reply
Thread Tools
  #241
Old 05-09-2019, 01:43 AM
vette427sbc's Avatar
vette427sbc vette427sbc is offline
United States | Addict
My Photos: (87)
Default
Quote:
Originally Posted by phantomjock View Post
Flares will be nice. With - or without the "mud-flaps?"
Looks like we've found the same wire-wrap materials (Alex-Tech?). It is the "fabric" that wraps/expands around like a tube? Not cheap - but way better than the old plastic spiral wraps! Understand no melt until about 400F.
No mudflaps! A feature I love about the 68/69 cars. The half wrap is still a tape, although pulls off without residue. The manufacturer is Tessa... I primarily work on European cars day to day and this allows me to make my wire harness/electronics look more factory. Using it almost daily, it grew on me... I really like the properties and I think it just looks cool! Only suitable for interior use though...
Quote:
Originally Posted by mfain View Post
looking GOOD! Out of curiosity why did you go with a 19" tire? There are a lot more tire choices, especially in track tires, in the 18" size.
Thanks! I really prefer C3ís with a 27Ē tall tire... I couldnít find anything (DOT) 345/35/18 I figure with vipers and corvettes running the 19Ē wheels I would have tire options for a while as well. Trying to build a double-duty car thatís still streetable and still trackable makes it a bad streetcar, and also a compromised race car. i think Iíll have a permanent smile on whenever Iím in the drivers seat though!
Quote:
Originally Posted by rtj View Post
A C3 with flares is always a good thing.
__________________
Chris
AutoWorks Middletown NJ
@autoworksnj
  #242
Old 05-10-2019, 11:10 PM
My Photos: (87)
Default
Some long term projects finally coming to reality! I think I started designing this radiator around January... C&R racing totally knocked it out of the park. Very easy to deal with, and helped with the design to make this as efficient as possible.
27.5" x 14.5", double pass 55mm core, extruded tube, type R fins. Sized to get it lower in the chassis and closer to the center of the car.
Still need to fab the mounts and hoses, but this is about where it sits
  #243
Old 06-23-2019, 12:26 AM
My Photos: (87)
Default
Slow, wiring is hard to show progress through photos. Hereís a few highlights... Doing my best to design this as an OEM might.
Ditched the generic Spal connectors for these high current weather proof ones from amphenol
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Alot going on back here... fuel lines, heater lines, and the engine bulkhead connector. This is a Delphi HES 29 pin, multi gauge. The distributor fits right in, and the harness can be unplugged without removing it
Also got the radiator mounts finished. .25Ē 6061. They are machined to match the angle of the tanks as they sit in the frame (40į lay-forward)
  #244
Old 06-23-2019, 03:16 PM
mfain's Avatar
mfain mfain is offline
My Photos: (6)
Default
Looking really good!
Pappy
__________________
Pappy
  #245
Old 06-23-2019, 05:11 PM
69427's Avatar
69427 69427 is offline
United States | The Artist formerly known as Turbo84
My Photos: (2)
Default
I agree with Pappy above: Looking really good! I'm looking forward to hearing your reactions/feedback from your first track day.
Question: Regarding the radiator, for the uninformed (me, specifically), what are type R fins?
Edit: Just wondered, any changes required to the hood hinge setup to clear the new radiator positioning?
  #246
Old 06-23-2019, 10:09 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (299)
Default
What are your plans for hoses? I (think) I will be able to use a stock bottom hose but the top hose is made from 2 60's cars cut in half and coupled together. I found them by going in the stock room at NAPA and searching the wall of hoses they had.
__________________
  #247
Old 06-26-2019, 03:04 AM
My Photos: (87)
Default
Pappy- appreciate it! Your car has given me lots of inspiration for many of the design elements on my car. So thank you for that!
Mike- The type R fin is Hard to describe... perforated maybe? There are fins on the fins! Iíll see if I can capture a picture. According to my eyeball, the hood should clear. If it doesnít, I will only have to shorten the prop rod slightly.
As far as track impressions; I canít wait either, but Iím just as excited to see what kind of street manors this car will have. Iíve got so much time in the design trying to make this balancing act work. As long as I canít out drive the car in the first few years of driving (I have a feeling Iíll still be dialing it in in 3 years) then Iíll be happy. I have a lot to learn as a driver as this is way more car than Iíve ever tracked. Well, itís alot of car on paper. We will know soon enough!
BBShark- im thinking something close to the stock lower as well... the upper will need to be three pieces, likely with a hardline making up 1/2 or a 1/3 of the length... Iím striking out at the finding something in the stock rooms at the auto parts stores. The hose has to be tight to the head and then to the coil over hoop to make room for the radiator exhaust duct, AND the crossbar. If you e got any pics of that you have for your upper hose, please share!
  #248
Old 06-26-2019, 04:31 AM
SuperBuickGuy's Avatar
SuperBuickGuy SuperBuickGuy is offline
My Photos: (0)
Default
that looks awesome enough to copy
  #249
Old 08-25-2019, 06:50 PM
My Photos: (87)
Default
Not much to update... but Ill hopefully be putting some more time into the vette soon. Im starting to focus more on the bodywork so I can get wheels ordered. I think being able to see it roll around on its own is more motivating to me than being able to start it. Plus it is a pain to push it around the shop on dollys. I did get the hood on it to start lining up the front clip so I can get my front fenders grafted in. I with I could say I planned this to work out so well, but the hood clears the radiator perfectly using the stock hinges. It was a good eyeballing "looks like this will work"
Heres one fender (very) roughed in. When you look at one of the flares, it looks somewhat subtle, but comparing it to a stock fender makes it a bit more obvious... Im going to try and hide the fact that its flared with a modified pace car spoiler down the road..
Off topic, but heres a few of the cars that have been taking time away from my car...
On our other shop car we did a major engine compartment update... a cleaned up "stock" looking smooth firewall/ wire tuck and a custom wire harness. Also did a little refresh on the Dart 406
Total opposite of the pro-touring style builds I generally prefer, this gasser has to be one of my favorite cars Ive had in the shop. Its a blast to drive!
  #250
Old 08-26-2019, 07:02 PM
BBShark's Avatar
My Photos: (299)
Default
That's going to look good. Who made the flares?
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
