Imo Apita
- Joined
- Feb 28, 2009
- Messages
- 244
Low beam headlamp
H5006
H5006XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
High beam headlamp
H5001
H5001XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
Parking light
1157A
1157ALL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
1157A
Rear turn signal
1157
1157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
1157
Stop light
1157
License plate
168
168LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
1156
1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
168
Rear sidemarker
168
Glove box
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
214-2
Step/Courtesy light
1445
1445LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
906
906LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Under hood light
1003
1003LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Instrument-general
161
161LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
194
558
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
Automatic transmission indicator
161
Directional signal indicator
194
Radio dial
216
________________________________________ ____________
The applications presented in this replacement guide have been compiled using the best information available from the vehicle manufacturers at the time of your search. This guide is intended for general information purposes only, not to be construed as any type of warrantee as to any particular application. For specific applications the vehicle owner's manual should be consulted.
Source: http://www.sylvania.com/ConsumerProd...RG-Results.htm
H5006
High beam headlamp
H5001
Parking light
1157A
Front turn signal
1157A
Rear turn signal
1157
Tail light
1157
Stop light
1157
License plate
168
Back up light
1156
Front sidemarker
168
Rear sidemarker
168
Glove box
194
Dome light
214-2
Step/Courtesy light
1445
906
Under hood light
1003
Instrument-general
161
194
558
Hi-beam indicator
194
Seat belt indicator
194
Brake warning
194
161
194
Radio dial
216
