  #401
Old 09-18-2018, 08:09 PM
SuperBuickGuy's Avatar
My Photos: (0)
I'm using the C5 because I'm widening the wheelbase - if I was going to use stock width, then the grand am for sure.
  #402
Old Today, 04:26 AM
My Photos: (0)
I got a stack of parts.... early, but not all correct
this one is correct (under the bubble wrap) it's a front sway bar for a C5/C6
rotors from a 2010-2015 Camaro was good too - though I need to do a bit of opening on the spindle
and they sent me the rear calipers rather then the front.... whoops.edited editedI sent the seller (ebay) a note, crossing my fingers he has the right ones.edited These use a 2" wide pad rather then a 2 1/2" wide along with the front rotor is thicker....
There is good news, though, making a bracket to make those fit the Corvette spindles should be child's play.edited Fortunately, I don't think there will be a run on these front end parts because this is not as plug and play as the rear..... of course, if it was easy....edited
I'm starting with a used C5/C6 front rack.... I'll make it manual, but it will give me the option of power if I don't like it... read, it makes me faster.
