  #1
Old 08-30-2018, 09:54 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (156)
Default Cooling the front discs.
Looking for a way to provide some fresh air to the front discs with the calipers in front of the spindles is not really easy.
So after some time trying to route the ducting hose with not a proper fitment, I decided to relocate the calipers at the rear of the spindles.
Way more room to do what you want !!
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
  #2
Old 08-30-2018, 11:17 AM
rtj's Avatar
rtj rtj is offline
My Photos: (41)
Nice job.
  #3
Old 08-31-2018, 12:54 PM
rtj's Avatar
rtj rtj is offline
My Photos: (41)
Are those calipers purchased with the two pin holes, or did you drill them yourself? Where are you buying pads? Duntov does that, but I know you mentioned importing parts is a pain.
  #4
Old 08-31-2018, 04:13 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (260)
Nice fabrication work!
What are the two screws at the top for?
  #5
Old 08-31-2018, 10:47 PM
redvetracr's Avatar
redvetracr redvetracr is offline
My Photos: (129)
very clean...you might do a search for the Guldstrand endurance kit, it spreads the caliper allowing thicker (endurance type) brake pads, something anyone with a milling machine could make, you can run a two piece hub/rotor also
  #6
Old 09-01-2018, 10:09 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (156)
All right , first thanks for the nice words all of you. Much appreciated.
rtj, I drilled the calipers, wanting to have my own J56. But with the bridge, it defeated the use of the bent pads. So.. not used.
For the pads, I am using an Australian brand made in Japan ! CIRCO , come in different compound . I am using a "softer " one a the rear , a set who is more efficient at lower temperature than the front.
BBshark, the two top screws are for a bracket who hold the cowling onto the top bolt of the spindle ( Holding the caliper bracket as well )
redvet, thanks for the tip, I know this one and it will be a evolution of the front brakes. I try to go slow with the mods as the Camaro guys are on the watch out for me
And about the rotors!?
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
  #7
Old 09-03-2018, 01:53 AM
69427's Avatar
69427 69427 is offline
My Photos: (0)
Nice work! I also like the flared lightening hole in the radiator crossmember bracket.
I don't have the tool to do that, so I had to do my brackets in aluminum. I also duplicated the crossmember shape in aluminum for about 4 or 5 pounds less weight.
  #8
Old 09-04-2018, 08:56 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (156)
This is what I did to the crossmember, cut some windows in it. I should have done the top side side as well, next time..
I must admit that I am taking inspiration from your car too , trying to make it as it was in 68/69 pre big flares period.
The best comment I had for the car so far, was from an older (than me !) gentleman who really appreciated the old school vibe of the Vette beside its sound at full chat.
  #9
Old 09-17-2018, 02:10 PM
rtj's Avatar
rtj rtj is offline
My Photos: (41)
Iíve been going through build photos, and saw a bunch of cars that added a second stationary cooling hose pointed directly at the caliper. May only be needed for a max effort, not sure.
  #10
Old 09-20-2018, 08:07 AM
OZgreen69's Avatar
Australia | Addict
My Photos: (156)
Yes, I have seen them as well, and all the answers I had to my questions about their efficiency were either: Oh yes it work really well , with no facts to back it . Or just a blank face.
I just have a AP temperature sticker on each caliper to monitor the heat.
We will see
