  #1
Old 06-07-2018, 06:23 PM
vette427sbc's Avatar
My Photos: (0)
Default C2/3 fuel tank swap
Anyone know if a C3 fuel tank will fit in a C2? I have a customer with a '66 Vert that needs a tank, and I have a good tank that Im not using from my '69 coupe... They list different part numbers online but it sure looks like it might be close enough to work. He doesnt care about originality otherwise Id just tell him to get the correct tank... he bought it in '69 and gave it the full 70's treatment; 6 tail lights, mudflap flares, shaved front bumpers, Ansen wheels, etc. I love it!
  #2
Old 06-08-2018, 10:27 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (260)
Here is a drawing of the frame for a 63-67. The back half were the tank mounts look different than my 68.
  #3
Old 06-08-2018, 11:12 PM
Geoff Coenen Geoff Coenen is offline
My Photos: (0)
63-67 tanks (except 36 gal.) only have 1 fuel feed tube coming out of bottom of the sender gauge & no vents
68-69 tanks have 1 fuel feed tube coming out of bottom of the sender gauge & can have a vent tube on the right side for vapor return depending upon HP.
Crimp vent flat & solder slip closed.
Both tanks have the same diameter for the sender hole & locking mechanism so a 63-67 sender will fit & mount in the hole. But 68-up senders are wired differently & cannot be used in a 63-67.
  #4
Old 06-13-2018, 09:04 PM
My Photos: (0)
Thanks for the info guys... $270 for a new tank and all necessary hardware/accessories for the correct year is worth not having to fuss with getting the wrong one to work
  #5
Old 08-02-2018, 08:31 AM
COLE SWEAT's Avatar
COLE SWEAT COLE SWEAT is offline
United States | Member
My Photos: (0)
About that 36 gal tank. Will it fit in a 69? And will the 69 sending unit fit the 67 tank (36 gal.)?
  #6
Old 08-03-2018, 05:59 PM
My Photos: (0)
I believe the c2 36 gal tank used a different floor in the rear to fit... it might be easier to just get a generic aftermarket tank and fab up some brackets to mount it... removal of the spare tire will likely need to happen though
Chris
AutoWorks Middletown NJ
@autoworksnj
