Go Back   VetteMOD.com > VetteMOD Technical Discussion > Paint, Body and Interior
Reply
Thread Tools
  #1
Old 10-27-2014, 08:36 PM
Garys 68 Garys 68 is offline
United States | Addict
My Photos: (0)
Default Painting over a glass hood with base clear on it now
OK, this question is from a paint/bodywork idiot....so be gentle.
I've got a fiberglass hood on my Olds ( I know, not a vette, but it is fiberglass )recently painted with base and flat clear coat.
I want to add a stripe on it to match the rest of the car (sunburst orange) with gloss finish.
Can buy a rattle can of GM 56 sunburst orange (ebay) and gloss clear. Tape off the area (fineline). Clean with prepsol. Rough it with 400 grit or scotchbrite. Then rattle can spray it?
A couple more questions: Is it necessary to sand between color and clear or can clear be applied while the base is still tacky?
And I was thinking about using fineline tape to leave a 1/4" flat black gap with a 1/4" orange gloss stripe on each side. Any hints on removing the tape at a certain stage of drying?
I know, this stuff is basic, but I'm bored with the flat black hood that I almost threw away.
  #2
Old 10-28-2014, 10:53 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (266)
Default
Is the rattlecan paint basecoat/clearcoat?
__________________
  #3
Old 10-28-2014, 12:26 PM
My Photos: (0)
Default
Yep, ebay, bought this to do some wheels, worked great.
  #4
Old 10-28-2014, 07:38 PM
MYBAD79's Avatar
MYBAD79 MYBAD79 is offline
Germany | Crew Chief
My Photos: (882)
Default
I doubt that a big area like a hood can be sprayed with a rattle can and look good.... problem is you cannot really keep it "wet" enough with the rattle can. Smaller areas work fine.... next question: is there any hardener in that clearcoat ?
I have successfully used rattle cans on small repairs and then clearcoated the panel with 2K clear... looked pretty good but it's not really something I'm proud of....LOL
__________________
Link to my garage:
  #5
Old 10-28-2014, 09:53 PM
My Photos: (0)
Default
Not a whole hood, just a stripe down the center.
Not sure on hardener in the existing flat clear. What do I have to worry about there? Btw, that's why I'm asking, incompatibilities.
  #6
Old 10-28-2014, 11:14 PM
MYBAD79's Avatar
My Photos: (882)
Default
One method to find out if the existing clearcoat is 2k urethane is to hit it with a rag and some laquer thinner... It won't touch 2k urethane but if it's single stage or some enamel etc it will soften it ... Test it on the underside of the hood ....
If you're not sure what it is, it might turn ugly after a while in the sun... Does the paint match the rest of the car?
  #7
Old 10-29-2014, 02:30 PM
My Photos: (0)
Default
Here's a pic, black base, flat clear on top.
Just planning a stripe down the center.
I've used the orange paint to do wheels before, it's a pretty good match.
What paints could be on the hood that wont work with the ebay rattle can in the link above?
  #8
Old 10-30-2014, 02:36 AM
MYBAD79's Avatar
My Photos: (882)
Default
If it is 2k urethane flat clear the rattle can paint is very likely going to work. Keep in mind though, you'll ha a rough edge where the shiny glossy clear meets the old flat clear. Eventually it will peel..... Might be 2-3 years but I would bet money that eventually it will peel.
Normally you would sand the entire hood, then layout stripes, mask, paint stripes with basecoat only.... Then unmask, wipe the hood with a tack cloth, verify all lines are sharp, then clearcoat the entire hood..... That flat/gloss clear thing is going to be a pain.....
  #9
Old 10-30-2014, 02:44 PM
My Photos: (0)
Default
Maybe I should just look for a sticker that matches the paint?
  #10
Old 11-01-2014, 12:52 AM
MYBAD79's Avatar
My Photos: (882)
Default
You really want to keep the flat black?
Here's what you cold try: sand the entire hood with 600wet, layout stripes, mask, paint stripes.... Unmask and shoot the entire hood with 3-4 coats flat clear.... Then buff the orange stripes... Flat clear turns shiny when polished-at least the PPG flat clear that I have used does......
Spray a test panel with base/flat clear first to see if it really works with your clear.....
That hood would look great in orange too !!!!!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
