Go Back   VetteMOD.com > VetteMOD Technical Discussion > Paint, Body and Interior
Reply
Thread Tools
  #1
Old 08-14-2017, 11:06 PM
84rzv500r's Avatar
84rzv500r 84rzv500r is offline
United States | Knows just enough to be dangerous!
My Photos: (105)
Default Roof panel single piece race weigh fiberglass
Roof panel single piece race weigh fiberglass, anyone still building these or do I have to pull a mold and make my own ???
the one I have is 1/2 thick and weighs a ton.
__________________
1971 Can-Am, 502 Ramjet, CC Rollers, hookers, 14 pt cage, Lakewood, McLeod RST DD, ROD 6 trans, 3.08 rear, Wilwood brakes, Hydraboost, Steeroids, Tubular A-arms, QA1 DA and Viking DA shocks, VanSteel HD offset TA's w/Johnny Joints, 6 link, 3" tele halfshafts, modded dragvette loops, 16 gallon fuel cell, basset wheels 15x10x4 with nitto 555r 275/50VR15, 15x12x4.5 with nitto 555r 325/50VR15's, Ultrashield seats, SW Clocks, 16" spal fan, Jones Racing RTP, FIA lights, Mirrors, Action...
  #2
Old 08-15-2017, 01:01 AM
rtj's Avatar
rtj rtj is offline
United States | Addict
My Photos: (67)
Default
Angle grinder, flap wheel sanding disk, and vacuum to thin it down? I see they still make the Astro top, but 17 lbs is probably too much. Check craigs list for an old hardtop and cut it up.
  #3
Old 08-15-2017, 04:58 PM
84rzv500r's Avatar
My Photos: (105)
Default
dont need the whole hard top just enough to replace the t-tops like the astro roof but thats way to heavy my current panel weighs 22lbs
In thinking about setting a 3/16 piece of dark smoke lexan on it and letting it set in the summer sun here and help it a bit with the heat gun. then trim to fit
thoughts?[Only registered and activated users can see links. Click Here To Register...]
  #4
Old 08-16-2017, 10:01 AM
phantomjock's Avatar
phantomjock phantomjock is offline
My Photos: (698)
Default
Lexan is not cheap and even with the dark smoke will heat the interior.
Check out Speedway Motors for some 1/8" plastic. Available in 10 and 25 ft rolls. [Only registered and activated users can see links. Click Here To Register...]
Under 20 bucks for the 10 foot roll - worthy of a trial for that roof.
[Standard disclaimer here... blah, blah, blah.]
I'll be using mine for the aero-underbody on the sports racer (as a trial) then on "Elvira."
__________________
Rebuilder's Zen Saying:
One thought leads to another. If these thoughts link into a chain we become bound to the project. This bondage is subtle and remains until we complete the tasks -- or, STOP Thinking!
  #5
Old 08-16-2017, 11:47 AM
84rzv500r's Avatar
My Photos: (105)
Default
I have a roll of that at the shop... makes nice inner fenders. Im not so sure I care about heat... more about weight and usability... I hardy ever drive the car down here with the top on...
I think the thing to do is pull a mold from my existing top and make a thin fiberglass one. a couple of spruce stringers to give it a bit of rigidity...
  #6
Old 08-16-2017, 06:04 PM
My Photos: (698)
Default
Sounds like a good plan:
Maybe core it with blue foam. Heat shape the foam to the inside. Then a thin layer of glass on the inside. Cut your laminates in half - half outside/half inside. Be plenty rigid and light too.
Good luck however you attack the projo. Pics as you go please.
  #7
Old 08-20-2017, 09:30 PM
redvetracr's Avatar
redvetracr redvetracr is offline
My Photos: (118)
Default
Motorsport Composite (formerly know as Competition fiberglass) in Mequon or Grafton WI has the mold, what you would get I believe is just a skin, call up there and talk with Wava Utt
__________________
  #8
Old 08-22-2017, 04:13 PM
84rzv500r's Avatar
My Photos: (105)
Default
thanks... giving them a call..
  #9
Old 08-22-2017, 04:35 PM
84rzv500r's Avatar
My Photos: (105)
Default
wonderful lady... be here in a week to 10 days and it comes in BLACK LOL
thanks Redvetracr !!
  #10
Old 04-02-2018, 12:55 AM
stingray composites's Avatar
stingray composites stingray composites is offline
United States | n00b
My Photos: (3)
Default
I was considering doing a carbon one piece top for these that will attach using quik-latches seems to be more people wanting astro tops than I thought.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
