vette427sbc
I see you closed the gap in the clutch rod hole. Are you using a hydraulic system? Do you think that plate is stiff enough?
The clutch hole is still there. I did fill the speedo cable hole though next to it. I've been running a hydraulic clutch for a while now and haven't had any issue with that reinforcement plate, but that was with a lighter pressure plate. The spec 3+ clutch is a little heavier on the pedal but I added some glass structure to the firewall when I filled all the other holes, and I think the load will be spread more evenly with the bonding agent vs the factory rivets. We shall see!
