  #1
Old 03-06-2018, 01:01 AM
vette427sbc's Avatar
My Photos: (2)
Default C4 rear caliper plate?
Potentially a long shot but does anyone happen to have a caliper mounting plate off of their car? I would greatly appreciate some quick dimensions if so: bolt circle and inner diameter.
I need to make a new one for a radial mount caliper and spot caliper.
Thanks!
  #2
Old 03-06-2018, 12:50 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (264)
Iv'e got one. I'll measure today and post
  #3
Old 03-06-2018, 07:22 PM
BBShark's Avatar
My Photos: (264)
Quote:
The bolt circle is 120.65mm with .497 dia holes. The bore is stepped into 3 diameters. The bore that fits to the carrier (in your picture) is 3.934 dia. The center bore is 3.776 clearance. The bore that fits to the wheel bearing assembly is 3.620.
The bracket is 1.560 thick.
  #4
Old 03-06-2018, 11:40 PM
My Photos: (2)
Perfect thank you!!
Ill post up my final drawing when its complete... C5 front rotor, Stoptech ST40 radial mount and an IPSCO mechanical spot caliper.
PS: Your bolt circle is center to center or edge to center?
  #5
Old 03-07-2018, 12:24 PM
BBShark's Avatar
My Photos: (264)
The bolt circle is to the center of the bolts.
Sounds like a nice setup. Looking forward to seeing it.
  #6
Old 03-22-2018, 04:15 PM
My Photos: (2)
Preliminary drawing to be 3D printed and test fit
