Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #1
Old 06-25-2017, 01:51 PM
Belgian1979vette's Avatar
Belgian1979vette Belgian1979vette is offline
Belgium | Addict
My Photos: (104)
Default Urgent Q about half shafts
Due to my recent bearing failure, I took my rear left suspension apart and have replaced the faulty bearings and associated parts.
I'm not moving onto assembling the trailing arm back into the car but stumbled upon something that seems like an issue.
I reconnected my half shafts (the lower camber rod is not yet mounted) and when rotating the brake disc, I get a point where it seems to hang up. I can see the trailing arm twitch somewhat. I'm sure this is not in the bearings as these turned fine when assembled on the bench. This appeared only after reconnecting the half shaft.
Now this is at full suspension droop because the car is on stands and no rear wheels in her.
When jacking up the trailing arm and rotating the disc it doesn't seem to be doing this.
Is this normal because of the half shaft angle or am I looking at a problem with my u-joints ? I did check them as good as I could while the axle was out and regreased them, but at that point I didn't notice anything abnormal.
__________________
Opinions are like assholes, everyone has got one, but everyone thinks everyone else's stinks.
  #2
Old 06-25-2017, 03:19 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
I would think you need that camber rod/lower link shaft on there, each side to keep your camber 1/2 was decent, otherwise that thing is all over the joint, and likely to hang up at some point....at that point you can just jack the rear at the diffy and set the arms on jack stands, and test it by hand by turning drive shaft....if that passes, try first gear and see how much it likes life... after that, try with just the jack on the diffy, and no stands....it should be happy even with shocks fully extended.....
__________________
  #3
Old 06-25-2017, 08:02 PM
JPhil's Avatar
JPhil JPhil is offline
United States | Huh?
My Photos: (140)
Default
It's because at full droop the angles exceed the correct angles of operation of the u-joints. That is to be expected in that situation.
__________________
Kill the Buddha
  #4
Old 06-26-2017, 12:00 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (264)
Default
Quote:
There's your answer. It doesn't take much droop to cause that.
__________________
  #5
Old 06-26-2017, 02:27 PM
mrvette's Avatar
My Photos: (3)
Default
Odd, in the past I know damn well I have run the '72 with the ass in the air, and not even thinking of the 1/2 shafts, never an issue....
  #6
Old 06-26-2017, 08:50 PM
Belgium | Addict
My Photos: (104)
Default
Well after some taking apart, checking remounting and such it was indeed the suspension that drooped more than normal. But the lower link wasn't mounted on the one hand and the shock wasn't in either. With these mounted I didn't have the problem.
However, now I have a brake problem *sigh*. But will make another thread about that one.
  #7
Old 06-26-2017, 09:55 PM
mrvette's Avatar
My Photos: (3)
Default
Last change I did on the rear was the Billy Stein shocks, and in fact I dunno if they have stock lengths to them or not, the Monroe shocks on previously did.....I have not run the car with the ass in the air in years now.....
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
