Go Back   VetteMOD.com > VetteMOD Workshop > Rebuilding Techniques
  #1
Old 12-06-2017, 02:50 PM
Bullshark's Avatar
Bullshark Bullshark is offline
My Photos: (192)
Default Trailing arm Tapered wheel bearing setup
I'm in the middle of upgrading my 1969 Blue Angel vert with RideTech suspension and have a question for you guys. (Hope GTR1999 chimes in).
All the how-to articles recommend setting the trailing arm wheel bearing endplay to .002" max. My buddy who owns Competition Marine Center and has much experience setting up tapered bearings on off shore race boats etc. tells me that I should set them up with 7-14 inch lbs of preload. I did a little internet research and found articles like this ([Only registered and activated users can see links. Click Here To Register...]) which tend to support his position.
So, maybe I'm poll vaulting over mouse turds here but which way is best and why?
  #2
Old 12-06-2017, 04:17 PM
denpo's Avatar
denpo denpo is offline
Canada | Carburated Nihilist
My Photos: (496)
When I did mine (prepared by Gary) I had to torque the whole setup to 100lbs and then check for the .002" endplay.
Less than that and the bearing are too compressed and will heat up, less you got too much play.
There is online rebuild guide somewhere even if I couldn't find it right now.
“In theory, theory and practice are the same. In practice, they are not.”
-Albert Einstein
  #3
Old 12-06-2017, 11:52 PM
Bullshark's Avatar
My Photos: (192)
Yes, That is the procedure I am familiar with and have used multiple times in the past. The point my buddy is making is that it is better to put a slight preload on the bearings. Evidently not enough to cause excessive friction heat that would effect bearing life. See attached article I found on the internet.
  #4
Old 12-07-2017, 06:03 PM
Red77 Red77 is offline
My Photos: (0)
You'll find that 7-14 is also common on the tapered pinion bearings on a diff.. That being said, I imagine the 100lbs/ft to make sure the races are seated and then the end play has come from year of experience setting these up. From what I understand there is definitely a right way and a wrong way to do it. My cousin rebuilt mine several years ago and used the end play method.
  #5
Old 12-08-2017, 02:28 AM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (299)
It seems like the preload on the bearing would be proportional to it's size.
  #6
Old 12-13-2017, 04:34 PM
Bullshark's Avatar
My Photos: (192)
Went with a slight preload. I'll let you guys know how it lasts.
