Belgian1979vette
Well, after a lot of issues and wiring problems yesterday I finally succeeded in firing up the engine on megasquirt FI.
Not even difficult to start, which, I guess, is a good sign.
BUT : my Aeromotive A1000 is one loud MF. I use a surge tank, with a Holley HP125 pump supplying the surge tank and then the A1000 supplying the high pressure. All pumps are well below the level of either fuel tank or surge tank, so that's not the issue. Fuel lines are large enough so that's not a problem either.
But the Aeromotive is so loud I'm not going to leave it in there.
Would like some suggestions on a good pump with some 400 lbs/hr flow at 45 psi pressure and silent...
Input is appreciated.
