Diameter of a CS133 and CS144 alternator
I have a PowerMaster CS144 sitting on the bench and confirmed these:
It is a BIG SUCKER! But, makes amps!
Can't provide the CS133 - but Jegs shows the GM CS130 dimensions as:
Can't say for CS 130 series -- but I know the CS144 does - at least in my case.
Alternative brackets are out there some are expensive. If you have access to a plasma cutter cut mount. Else Jegs has one for less than 100 bucks that fits.
Or mount low on passenger's side, etc.
