Go Back   VetteMOD.com > VetteMOD Technical Discussion > Engine
Reply
Thread Tools
  #1
Old 12-26-2016, 03:57 AM
69427's Avatar
69427 69427 is offline
United States | The Artist formerly known as Turbo84
My Photos: (2)
Default Accusump install and oil filter question
Kicking around putting an Accusump under the hood over the winter. One question that's bothered me is what happens when the oil filter is pressurized in the opposite direction when prelubing the engine prior to start-up. Do the pump gears create enough restriction to prevent just back-flushing trash out of the filter and pushing it back into the pan? Or, will the reverse pressure swell the internal filtering media and possibly weaken/damage it?
Am I over-thinking things, or just over worrying?
Thanks for any constructive info.
  #2
Old 12-26-2016, 10:12 AM
phantomjock's Avatar
phantomjock phantomjock is offline
United States | Addict
My Photos: (699)
Default
Don't know/can't say if over thinking/worring too much. I did recall it should be pressureized @ normal running pressure, so had to take a look at my files. [My acculumulator is awaiting install too]:
Could plumb directly to the oil galley. That gets it where you want it, but the pump could still be there. Covers the bearings for sure, maybe not the top end? Could be a little more work and chance for a WIAT* though...
*"While-I'm-At-It"
__________________
Rebuilder's Zen Saying:
One thought leads to another. If these thoughts link into a chain we become bound to the project. This bondage is subtle and remains until we complete the tasks -- or, STOP Thinking!
  #3
Old 12-26-2016, 12:18 PM
rtj's Avatar
rtj rtj is offline
My Photos: (60)
Default
I was curious too. The PDF instructions show a check valve.
Fig 2.
Keep us updated on this upgrade. I'm interested to hear more.
  #4
Old 12-26-2016, 07:32 PM
69427's Avatar
My Photos: (2)
Default
Fig 2.
The problem with a check valve is that there needs to be more external plumbing to put the valve in the Tee line. I just want to run the line from the Accusump to the threaded port above the oil filter boss. I need to do some additional research, and I'm curious if there's a PF-25 filter version with a checkvalve in it.
  #5
Old 12-26-2016, 07:50 PM
Belgian1979vette's Avatar
Belgian1979vette Belgian1979vette is offline
Belgium | Addict
My Photos: (104)
Default
I have one installed and if you don't use any kind of one way valve, they oil flows backward.
To note is that the one way valve that Canton supplies is a serious restriction to oil flow. I ended up using a ford filter that prevents reverse flow. Works like a charm.
Oh and connect the accusump in between the filter and as close to the block as possible.
__________________
Opinions are like assholes, everyone has got one, but everyone thinks everyone else's stinks.
  #6
Old 12-26-2016, 10:18 PM
rtj's Avatar
rtj rtj is offline
My Photos: (60)
Default
Might be a good time to add an external filter and oil cooler. I don't like the idea of back-flowing the filter either.
  #7
Old 12-27-2016, 03:01 PM
Belgium | Addict
My Photos: (104)
Default
Forgot to mention that : a remote mounted filter.
  #8
Old 12-30-2016, 03:38 PM
Grampy Grampy is offline
My Photos: (3)
Default
You know this additional oil adds weight - you'll have to diet.
This may not pass the constructive info test but my friend has a Rolls Merlin powered ride that uses a pre-oiler.
Happy New Year
  #9
Old 01-03-2017, 04:43 PM
rtj's Avatar
rtj rtj is offline
My Photos: (60)
Default
I was curious how the cost of the accusump compares with a dry sump system, and according to this article it is roughly $500 compared to $3500. Ouch.
I just grabbed the kit cost from jegs for the accusump.
A used pan and oil drive tank would probably drop the price of a dry sump a lot.
  #10
Old 01-04-2017, 02:08 AM
69427's Avatar
My Photos: (2)
Default
Found a couple filters with anti-drainback valves (according to the Summit website). The Wix 51060 and the AC 19187301 appear to be some parts to try. Just for amusement I think I'll e-mail Wix and ask if higher reverse pressures (during pre-lubing) cause any durability issues with the valve, and typically what is the forward pressure drop across the valve.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
