Go Back   VetteMOD.com > VetteMOD Technical Discussion > Other Cars
Reply
Thread Tools
  #1
Old 10-10-2017, 11:23 AM
rtj's Avatar
rtj rtj is offline
United States | Addict
My Photos: (17)
Default Another money pit
Finally slowed down on my home improvement projects to get my Camaro running. It has sat for 5 years.
Everything was done to support 1200 hp, but the engine is just a beat/abused 502. Timing is locked and I need to mess with the 7531 box some more. I've got to pull the rad and install the crank support and intercooler.
The original plan was use the 502 to learn blower basics, but who knows where this will go. People say a 502/F2 can do over 800hp (with cam, et cetera ).
  #2
Old 10-26-2017, 10:39 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
Default
Not much left to do now. Modified the crank support for use with a procharger.
  #3
Old 10-27-2017, 04:57 PM
Red77 Red77 is offline
United States | Member
My Photos: (0)
Default
That's a serious piece of hardware! Better than snapping off the snout though.
  #4
Old 10-27-2017, 05:47 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
Default
Apparently you can do considerable damage to the crank and main bearings without one. Especially with cog belts.
  #5
Old Yesterday, 04:48 PM
rtj's Avatar
rtj rtj is offline
My Photos: (17)
Default
I got to the point on the house where any more improvements will be diminishing returns, so I’m working on the cars more.
Made this in order to pin the balancer properly. The gen v has a large key, but I was afraid 1 key wasn’t enough.
Got the mandrel in at +/- 0.001”. Took a lot of fitting/machining to get the mandrel right. Then more fitting to get the bearing on with no bind.
Did some polishing and made a blower strut rod support.
My amazon 50$ valve covers. Need to drill and weld in 16an fittings on both for vent lines. I’m currently notching the other for blower clearance. Glad I’m not hacking up $300 valve covers.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
