Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #1
Old 08-11-2021, 11:12 PM
mfain's Avatar
mfain mfain is online now
United States | Addict
My Photos: (6)
Default Ron Sutton Suspension Components
For those that might have concerns, here is a link from Lateral g showing photos of cracks in Ron Sutton front suspension components. Looks to be a metallurgy or heat treat problem.
__________________
Pappy
  #2
Old 08-12-2021, 12:57 PM
BBShark's Avatar
BBShark BBShark is offline
United States | Garage Monkey
My Photos: (574)
Default
That is weird. Stress cracks that open a gap.
__________________
Political Correctness Is Just Fascism Pretending to Be Good Manners - George Carlin
  #3
Old 08-12-2021, 02:59 PM
mfain's Avatar
My Photos: (6)
Default
Quote:
There is now a bit of an explanation from the owner on the link. The LCA front pick-up point was cantilever and unsupported, so it was flexing with braking and cornering. Apparently the flexing (bending) back and forth caused stress cracks that eventually resulted in failure. I worked with Ron some on suspension geometry. He had a good understanding of dynamic suspension changes. But, in the end, I opted to build my own control arms and suspension mount points. Some of my stuff is a little heavy, but it shouldn't fail. I never liked his lower control arms (curved, unsupported rear link) and I guess there have been a couple of failures there too.
  #4
Old 08-22-2021, 07:00 PM
rtj's Avatar
rtj rtj is online now
My Photos: (108)
Default
There is a reason people use round holes to remove weight. All those triangle holes just invite metal fatigue/crack initiation.
  #5
Old 08-23-2021, 09:56 PM
vette427sbc's Avatar
vette427sbc vette427sbc is offline
My Photos: (144)
Default
This is a major bummer as Ive got my drysump drive pulley and power steering pump in close enough proximity to make bracing that LCA bracket way more complicated than it needs to be... Better to catch now, than later I suppose. Thanks for the heads up, Pappy
PS I went to visit my car at the fab shop in NH this weekend... Slowly, but surely
__________________
Chris
AutoWorks Middletown NJ
@autoworksnj
  #6
Old 08-25-2021, 04:10 AM
mfain's Avatar
My Photos: (6)
Default
Car looks great! You might get by with a simple bracket that supports the top of the control arm mounting tab and ties it to the connecting crossmember. Or, if you have room, a "bridge" between the pick-up brackets. Looks like the failure was because the control arm was pushing on the bolt above where it was supported, if that makes sense. It might get a little tricky under the rack on the driver's side. I talked to the guy who was driving the Chevelle when it broke. He said the geometry (roll center, caster gain, etc. was good, but they did go with a softer sway bar and less front end travel.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
