Yellow73SB Well-known member Joined Mar 24, 2008 Messages 1,201 Reaction score 0 May 17, 2009 #1 Which one is putting fluid out? I found this picture 4
Twin_Turbo Der Maulwurf Joined Mar 5, 2008 Messages 7,575 Reaction score 6 May 17, 2009 #2 #9 is cooler return (in) #8 is cooler feed (out) #2 is the pressure port (for hooking up a pressure gauge)
TimAT Addict, Cruise-In Bird-Run 1 Veteran Joined Mar 24, 2008 Messages 1,969 Reaction score 0 Location Gladstone, Missouri May 17, 2009 #3 #5 is a 3rd gear pressure switch for ECS- retards spark in 3rd gear. #6&7 are the same thing- 7 is the detent cable connection and 6 is the bolt that holds it in.
