Stingxray
Well I've made progress with the the Pier-Paolo Lucaroni suspension build.
Pieces are cut for 2 sets and I have some leftovers. I'm starting to polish the parts before I have them welded. Understanding some discolor will happen when welded. I found Stainless will Rust If not pre-paired correctly. The trick is sand and polish to close up the pore's of the steel. I bought my stainless plate from a recycle dealer (with scratches & surface rust) to save $$$ .............. most of the tailing's ends up in the scrap bin anyway. I'm looking to see if anyone has measurement for the 4 stand off spacer's on the differential. Also the length of the heim joint rods? Pier said the 4 front links are the same as the C-4's long rods witch I measure at 13 inches eye to eye. Any help is appreciated :crutches:
