Go Back   VetteMOD.com > VetteMOD Technical Discussion > Chassis, Steering and Suspension
Reply
Thread Tools
  #31
Old 04-30-2014, 12:41 PM
mrvette's Avatar
mrvette mrvette is offline
My Photos: (3)
Default
Quote:
Originally Posted by BBShark View Post
You could co that Gene but you would lower it at least 3 inches. Thats has it's own problems
So maybe cut/weld a new end on the lower control arm??? just seems simpler than going hog wild with money or modifying cast spindles, etc....rather weld a hunk of stamped steel and get it right the easy way....NO??
__________________
  #32
Old 01-27-2019, 06:33 PM
phantomjock's Avatar
phantomjock phantomjock is offline
United States | Addict
My Photos: (667)
Default Rehash - Reopen/Revive old thread...
Wondering if anyone has the details on the C4 front hub/spindles? if that would get to a drop - although some geometry to work out too.
BBShark has some nice CAD work for the C3 spindle -
but I can't find a C4 front hub/spindle CAD or dimensioned drawing to save me.
Also wondering if anyone has seen these over at Jegs and if they might fill the bill?
__________________
Rebuilder's Zen Saying:
One thought leads to another. If these thoughts link into a chain we become bound to the project. This bondage is subtle and remains until we complete the tasks -- or, STOP Thinking!
  #33
Old 01-27-2019, 11:07 PM
My Photos: (667)
Default
OK - I may have found a workable approach to this . Seems that a number of Chevys use the same Ball Joints, so the issue becomes which one you'd want to use, then see if you can source a dropped spindle for that model Chevy.
You could also retaper the spindle mount, but that is more work and machine shop time.
Here is a table I found that might be of use to others:
The 58-70 Caprice, Impala, Bell Air, and Biscane all share the same upper and lower Ball Joints as the 63-82 Corvette! Note the unit available a Jegs I posted earlier "looks" like you could remove the spindle and re mount it lower to get less than 2 inches drop.
"Case Closed!" YMMV.
  #34
Old 01-27-2019, 11:49 PM
vette427sbc's Avatar
vette427sbc vette427sbc is online now
My Photos: (99)
Default
Looks like it will work, but will it actually work
The *potential* KPI and ackerman differences could negate the benefit of the IC correction
__________________
Chris
AutoWorks Middletown NJ
@autoworksnj
  #35
Old 01-28-2019, 10:35 AM
My Photos: (667)
Default
The KPI looks to be about 3 degrees different between the JEGS spindle and the C3 (using jpeg measurement from the model of the C3 that BBShark did) Jegs version is 3 degrees "steeper."
RideTech has one they sell for the C3 that also raises the upper Ball Joint. They claim a huge improvement in Ackerman. But, you'd need to invest 400 bucks on that bet.
I've got a PM to Mike (69427) regarding his C4 front end mod. We'll see what he's found out.
  #36
Old 01-28-2019, 11:12 PM
rtj's Avatar
rtj rtj is offline
My Photos: (67)
Default
The tall ball joints are available. Howe’s racing.
Can you find an Impala dropped spindle? Edit: looks like you can, 1969 is the year I think.
  #37
Old 01-29-2019, 12:46 AM
My Photos: (667)
Default
Right - I have the Howe's. Think the "screw-in" versions I got from Colemans. The Moog K5108 is the part as best as I recall.
I think the "mix" is between the several interfaces. First the UCA/LCA to the screw-in Ball Joints (that must be picked to match the spindle). Then the spindle that is picked for KPA, drop, and Ackerman! Then, the Wheel/Tire combo - to house the gear, and then all that stirred in a witches brew to get favorable handling.
The Jegs (and others similar available) might be close enough to do a quick trial if can keep in the lower cost range (trial a less than 150).
I've looked at C5 and C6 hubs and there is not much change in spindle height - if any. C4 - still TBD. The whole thing I'm "worrying here" is the 2" raise I did to the differential. OOPS - now need to work the front end! The big difference using C5/6 on front end seems in the CA angles, lengths, etc, not in this aspect.
So what next... I'm waiting to get some words with 69427 who has done a few C3s to C4 front end mods. And, get up the "nerve" to drop some cash on Suspension Pro! It's just nearly time to do that.
Cheers - JIm
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
