Kid Vette
Master-Baiter
I decided to put some spacers between the wheels and hubs. The AR wheels I'm running have -6mm offset and stock Vette wheels have -12mm. The wheels clear everything without spacers but wanted to push the wheels out to fill up the wheel wells a little better. I got the spacers from Motorsport Tech and was very pleased. They look good and they held the diameters to pretty close tolerances. They cost $140 for a set of 4 and took about a week and a half to get them. The spacers are 6mm thick and are hub and wheel centric. I'll let the pictures tell the story.
I bought a set of ET lug nuts from Jegs so I will have the same thread engagement.
So I know spacers are supposed to be bad, but I'm thinking this is probably better than the setup I had where there was clearance on the hub and the lug nuts were the only thing locating the wheel.
