damoroso
Well, got step 1 done to paint my car, the paint is stripped from the front end. Used a combnination of stripper, a putty knife and a razor blade. I found at least three layers of paint on the passenger side, but there only seemed to be two on the drivers side. What I'm not sure about is the additional white coating that was under most everything including the bumper. It was over the last layer of primer, and when the stripper hit it, it melted. This is a Bowling Green car and that white stuff didnt' react the same way to the stripper. I think the car may have had a front clip put on at one time, maybe one from a St. Louis car? They used a different paint in St. Louis right? Oh, and there was a skim coat of filler on the tops and rear of the fenders, almost the entire surface. Took alot of work to get that off!
I knew there were problems under the paint and I knew the car had been hit in the left front corner. The left fender ridge line had been sanded out towards the bumper cover and there were cracks in the paint or ridges that showed and just so happen to be right where repairs were made. The issues that showed up in the paint were at the front left corner, the top rear of the fenders and along the end of the fenders by the doors.
Next I'm thinking I have to remove the bondo to see what's under it particularly in the corner where the most damage was. Then decided how to atually fix it. The left head light door needs some work too, looks like the two front corners were bent just a bit too.
I don't see any problems over the rest of the car, but I'll probably strip the paint off still, just to be sure. It's been over 20 yrs since I've done this, so we'll see what happens!!
