JeffP1167
this is on my 97 camaro with 3.8 v-6. I see like what looks like charcoal particles built up on it's screen, the map sensor has like torx screws with little pegs in the center. Is it safe to mess with this and pull it out then spray the screen with carb cleaner?
It also has what looks like a snap ring that secures the screen but not sure if the screen will get damage if trying to remove it like that.
This isn't a separate map sensor it is all built into the throttle body
any of you service one of these ????
