Fabbed Aluminum diff crossmember
438vette
Member
I guess this will be my first post on the board since i found this place. So far this is my first winter project that I completed. I'm pretty happy with the results.
So it started out that I was just going to make those aluminum disks to shore up the diff crossmember bushings. But it turned into a complete fabbed aluminum crossmemeber. And since i had to cut those ugly spring bolts I fabbed up some adjustable hiem joint spring links. I took it for a test drive and the rear end feels a lot better. Now I just need to get some sway bars on the car.
Now that's interesting
Welcome to Vettemod
Thanks guys.
The cross member ended up 12 lbs lighter than the stock piece, weighing in at 10lbs total. I used 1/4 wall aluminum rectangle tube. I would have gone with thinner tubing but my analysis software wasn't cooperating and didn't have time to figure out why.
Thanks guys.
Did it make the diff lower?
I left the diff at the stock height. If the round end's were machined longer yes the cross member could lower the diff.
I calculated 5 degrees, but the drivers side is not perfectly round or at least my frames nub wasn't. So i had to get it close, remove it from the lathe test fit, indicate it back in take a .010 pass and repeat till it fit snug up on the frame.
I wonder what kind of tolerance those have car to car... I dont recall the exact number I got but I think it was around 3 degrees?
I already cut the wrong taper once in a set of alu. bushings I made and I really dont want to do that again.
It seems like the drivers side nub was oblong as the grease was only leaving two spots where the passenger side was more round. By making the drivers side nub oblong it acts as a side to side centering pin, the passenger side is the fixed point and allows the front mount to float. I'll admit that 5 degrees may have been too much as it really only touched on the smallest part of the nub closest to the bolt. But all you really need it to do is center on the nub.
Looks like the stuff on the black/red C2 race car doesn't it??
Someone help the clueless here (moi).
Maybe Howard still has the pics, I lost all of my race car pics in a drive crash./ IT's a black with red stripe C2 from a former nissan engineer I think, Howard knows the details. that car has a lot of nice parts, including spring hangers like above.
Great work. And welcome. We all get our hands greasy here.
George
