COLE SWEAT
- Joined
- May 8, 2013
- Messages
- 142
I tightened the adjusters to the joint
Does that look about right?
As you can see I don't have too much room between the adjuster and the welded nut on the outside of the frame
above is the Guldstrand set-up, the above parts were once mine I had sold, he posted dimensions for me for a car I had that was originally built with this set-up later modified with a 5-link leaving only the 4 nuts welded is, I had everything else made locally...Found this.
