Electrical quandry.....
Oahuyahoo
Member
Turn signal went out OK not problem, the bulb was melted into the housing, OK screw me like that after all it is only a vette. New housing and replaced socket OK no problem.
Look how hot these got .
New harness OK fine and dandy.
I have all connections properly done and now I have headlights that don't close. No dash lights, or foglights. If that litttle bulb is a running light I can't get it to come on if my life depended on it.
Turn signal lever is new.
Checked most of the fuses, not all of them, the ones I thought would affect this situation. Can someone please help me, I am just beside myself with this as I have done nothing to cause these problems.
2004 vette coupe
For all that amount of stuff to go wrong at the same time a little common sense tells you it just might be fuse related and sure enough, after the engine box fuses I checked the passsenger floor board fuses and that's where it was. We're all good to go now, thanks for all the input.
:cheers:
C-5's eat front turn signal sockets. I've changed a few....nice design, GM.
Wife's Escort, all 4 corners, same shit, changed one corner 2x been about 5 years now.....gimme a 1157 with a phenolic wire/contact base...
screw all this crap bulbs.....ever see the bulb display on the part house rack these daze? freeking stupid, that's all...it's a damn lightbulb not a Picasso....
:hissyfit::hissyfit::clobbered::hunter:
