69427
Took the '84 for a test drive today. The last time I drove it was at a track day in Michigan in 2004. After three moves from Indiana to Orlando to Kansas City and some no-start issues after sitting during this time I final got it runnable. Been wanting to upgrade to a bigger/newer/more efficient turbo for quite a while so I thought I'd try to get some data to see where I'm at right now. Modified my present test gauge setup so that the gauges are no longer on an angle.
The Magnehelic is plumbed to the turbine outlet downtube, the higher range gauge hooks to the turbine inlet, and the small gauge is the manifold/boost gauge. I still need to add one more gauge to measure the compressor inlet pressure to see how much drop I'm getting across the throttle blades. The wires hanging in the picture are from a buffer circuit that ties into the ESC module and flashes a retina burning bright LED I have attached to the rearview mirror to let me know when I'm getting detonation (and telling me to get my foot out of the throttle).
I put my track day exhaust on the car as it has less backpressure and will simplify the gauge readings and make some of the future decision making calculations easier.
The 3 1/2 inch track exhaust is 30# lighter than the stock mufflers and Y-pipe (20# vs 50#). Plans are to replace that over the winter with a 4" aluminum piece that should take another 10 pounds off the car.
Took the car out for a drive on some of the back roads, and got into the throttle after the engine warmed up. Didn't have my accelerometer hooked up but I swear this 355 pulls every bit as hard as the 427 in the '69. I only tried one WOT run as I heard the engine detonate pretty quickly, reminding me that there's still a half tank of 2-4 year old fuel of questionable octane.
I've missed all the track days this year with this car but I'm going to make sure that all the updates are done in time for spring track days.
