Belgian1979vette
I already asked on another forum but no final solution yet. The thing is I'm running a HV pump with 75 psi spring and anti-cavitation slots. I have a oiling system including Canton 15-240t pan, thermostat, B&M Hi Tek oil cooler (stacked plate), accusump (with epc valve), remote oil filter.
The thermostat normally bypasses (up to a %) as long as the oil is not fully warmed up.
Getting around 75 psi when cold. No problem there.
Last weekend, with +30°C outside temps, engine got to 210°F. As soon as it was getting warm, I had around 55-60 psi oil pressure below 5000, around 25-30 hot. But going over 5000, made oil pressure go down...I saw it go untill 45-50 psi.
There is some debate about the accusump having a tendency of overfilling the pan, but I somehow have the impression that the oil cooler is causing the restriction.
Anyone ever run into this same problem with the B&M ?
PS : I know there is debate about the HV pump, but I run a pretty large system and spring oilers. There is no way on earth the pan gets sucked dry as all excess oil normally gets routed back to the intake side of the pump.
