MYBAD79
Moderator
Here's a few photos of my body mount replacement. I did this without lifting the body off the frame.
I lifted the body only 1" - that's enough to slide the mounts in and out. I used two mech scissor jacks under the floorboard. Place a 2x2 foot piece of plywood between the jack and the floorboard to prevent the jacks from penetrating the fiberglass.
Only the battery ground cable needs to be disconnected, that's pretty much it. The body needs to be lifted only 1". Everything else is flexible enough to allow this movement. If you want to lift 2" then disconnect the steering and brakelines from MC to frame.
I cut the fiberglass at the #3 mount to gain access, after I glued it back in place it's not noticeable.
I did one side at a time, driver's first, then passenger side. After all eight mounts were replaced I verified the loading is pretty equal on all of them with all bolts loose - none of them was moveable after shimming.
I did not tighten the bolts until all eight mounts were replaced and I verified all eight were 'loaded'. I checked all eight mounts and made sure that the body's weight is on the mounts - if you cannot turn the poly block then it's fine - if one ore more are loose then you'll need to add shims until all eight are equally tight...
These shims are available at Lowe's or HomeDepot in different thicknesses, these are fender washers, they're about 13 cents each....
Photos:
old body mount cushion:
more old stuff:
Photos:
more old stuff:
		 ush:
ush:
