  #761
Old 01-04-2020, 01:47 AM
bobs77vet's Avatar
My Photos: (12)
that's a really nice job on those.
  #762
Old 01-06-2020, 04:47 AM
SuperBuickGuy's Avatar
My Photos: (0)
beta version
supervision and complaints to Buick
remove all this stuff
install precision brackets and ram
and voila
Video of it opening fully
  #763
Old 01-06-2020, 05:34 AM
My Photos: (0)
one of the videos I watched used carb cleaner to clean the pistons... as I'm not thrilled with the solvent method, here we go
then time to knock cam bearings in place... what a pita
then slid the cam in place
and set the crank in place....edited
  #764
Old 01-08-2020, 02:39 PM
My Photos: (0)
Pistons are coming out nice from the carb cleaner
in other news, I got the parts from Aiden American so installed them
  #765
Old 01-13-2020, 05:38 AM
My Photos: (0)
finish up the suspension
tighten it down and level it up
so I can go onto the next 'big' thing
this side is good enough, not perfect, just good enough
this side is terrible
no going back now
first test fit
second fit
much better
what they did wrong was not do the same wheel opening side to side, the left side had a hook at about 2 o'clock.... cut, slice, dice and move forward so it's a radius and it's 'fixed'edited next up a lot of epoxy
then onto this issue
the hood doesn't follow the shape of the fenders... it's like they all got together and decided to use the one Corvette that was no other
​​​​​​​ah well, I have epoxy, fabric and I know how to use it....edited
  #766
Old 01-13-2020, 06:16 PM
69427's Avatar
69427 69427 is offline
My Photos: (2)
I gotta say, I admire your patience and determination.
  #767
Old 01-14-2020, 04:24 AM
My Photos: (0)
tonight's fun.... tighten crank bolts
check the rings.... .018 and .019 2nd.... need to file fit to .020 and .022
which stops that because my filer is broken....edited
how I keep the rings square
got stopped now waiting for parts that may or may not arrive on Thursday (we have a snow 'event' - which usually means nothing gets delivered)
The C3 didn't get any love because the epoxy I have is not cold weather stuff.... so waiting on parts there too
  #768
Old 01-15-2020, 03:44 AM
bobs77vet's Avatar
My Photos: (12)
very nice, I wonder what BG44k would do for cleaning pistons?
  #769
Old 01-15-2020, 05:17 AM
My Photos: (0)
no idea what that is
so I didn't want to wait until it warms up so I bought colder glue
glue it, pin it, wait 40 minutes if 40 degrees
and it's there
next up fiberglass the inside of the fender (which I am NOT looking forward to), then fill the seam and start body work.... and raise the scoop... and do the rear fenders.... and do the rear floor....edited
  #770
Old 01-15-2020, 10:50 AM
phantomjock's Avatar
My Photos: (670)
Default Panel Joining Tip
An idea I use - but, I bet you've started already:
  1. Layup a few pieces of cloth on a sheet of glass. Width, length, and number to gap-fill.
  2. Wet out and let kick.
  3. Remove from the glass
  4. Adhere to the inside. (Assuming adequate surface prep there too.)
  5. For added structural strength -- do several layers (follow-on ones wider of course.)
  6. Continue layup/smoothing of outside.
  7. Prep and paint.
The trick is to get just enough in that layup to remain flexible, but firm enough to support the outside, and tie the two together.
Less mess than welding overhead!
Rebuilder's Zen Saying:
