JeffP1167
OK I know nothing about this van. Problems started about 3 weeks ago with it and scan of the ecm was done.
here are codes that came up
C1145 no dtc definition found
C1103 no dtc definition found
U1262 standard commuication bus malf
B1318 battery voltage low
po302 miss detected #2 cylinder
I replaced the plug which looked heavily fouled and the plug wire and the battery just because it was old.
Now the van check engine light no longer comes on (unless it hasn't been run long enough) however it still cranks longer to start then it used to and engine still misses heavily.
I might have crossed plug wires who knows.
I honestly hope I did the right plug LOL
its a 3.8 V-6 is this the correct cylinder order?
windshield
123
456
And what is correct position of plug wires on the coil pack?
windshield
123
456
