Go Back   VetteMOD.com > VetteMOD Technical Discussion > Paint, Body and Interior
Reply
Thread Tools
  #91
Old 08-10-2009, 01:27 PM
saudivette's Avatar
saudivette saudivette is offline
Australia | Clueless In Sandland
My Photos: (334)
Default
Yeah, the gel coat on the nose cone does seem pretty thick
__________________
Understeer: when you hit the wall with the front of the car.
Oversteer: when you hit the wall with the back of the car.
Horsepower: how fast you hit the wall.
Torque: how far you take the wall with you.
Wayne Of Arabia,
Sand Happy
----->[Only registered and activated users can see links. Click Here To Register...]<-----
  #92
Old 09-19-2009, 01:04 PM
saudivette's Avatar
My Photos: (334)
Default
Bit of an update here and maybe get your opinions. I've done bugger all on my Vette since my mate out here died in July but I started tinkering again the last couple of days.
I've pretty much finished repairing the nose cone but long ago, I decided that the original front grille/indicator setup were lame. I thought about buying a pair of earlier model ones to mess around with until I saw the prices of them! So, I found some grille material and came up with this:
I'll (probably) paint them black. I'll sand down the "fins" on the orginal indicators and polish the surface again. To mount them, they'll basically go in the same place as original but I'll have to "shim" them rearwards a bit and I'll need to cut up the original louvers for the indicator mounting brackets.
Flame suit on...
  #93
Old 09-19-2009, 03:27 PM
BBShark's Avatar
BBShark BBShark is online now
United States | Garage Monkey
My Photos: (321)
Default
I think a little finer mesh would probably look better?
You can also form a perimiter flange on the finer welded mesh stuff over a peice of wood. That might give it a more finished look (like a perforated metal grill over a speaker).
__________________
  #94
Old 09-19-2009, 04:03 PM
saudivette's Avatar
My Photos: (334)
Default
I see what you're saying but I was trying to achieve a 70-72 look to go with my side louvers...
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
