Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
I'm helping a buddy fix up his 63 Corvette Convertible 327/300HP Automatic.
Couldn't have pulled if off so quickly without the help of Mike Dyer (Tracdogg), he's an awesome guy, collecting all those parts from various sources, never tired of answering a question. Mike's the best in my book.
It's an original German car (metric speedo)...
.... and used to belong to his father. This car was actually rescued from the junkyard many years ago. The original engine had seized in 87 or so and was replaced with a smogger 350 from a 80s G20 van/ambulance. Something had to be done about that. After tearing the motor apart it was sent off to the machine shop for rebuilding. We tore out the smogger motor and I persuaded him into doing a complete frame off on the car, hate to do things half assed.
Here's the old 327 after tearing it down...it's just a bit kaput
that's what you get flogging it on the Autobahn and the oil pump drive shaft comes loose
Initially my bud figured he'd get this done with a little wire brushing, all that dirt and grime...what a mess
Turned out the car had been wrecked, just looking at the frame I noticed the pass side front susp. was off ...further inspection learned it was off by as much as 2cm and the fender had been repaired, the inner fender was pop riveted together and the rad frame was held in place with a sheet metal plate and kitty hair. The tire was rubbing on the shoddy repaired. Case closed, time to pull it apart. The most astonishing thing was the center link, it was bent, someone must have heated it and bent it to make the car track straight again.
Bent rad frame
Cracked battery box, have to fix that.
Old grimy parts
frame back from blasting after straightening (you can see where it was torched to heat it up)
repairing the dented frame
Bent rad frame
Old grimy parts
