1958 MGA Coupe
vacation and taking little joe back to college has slowed me down a little bit. i just got word that my replacement driverside swivel pin and trunnions are going to get shipped out soon. this will let me finish the front end rebuild.
slow parts for MGs.... seems like there's a joke in there, somewhere :crutches:
i cant bitch about this on the MG forum since i am getting the parts from a member but this guy is just screwing me with the shipping of them ....hes just an old guy with just other things that are more important then selling the parts he advertised he wanted to sell. i finally linked him to the USPS site where they will send you the box at home and you can print the label and then a schedule a pickup with out ever having to leave the house so finally yesterday i got a shipping notification for a scheduled pickup today.
i just hope the parts are the right ones and in good shape or i will have wasted what seems like 2 months
been there on that one - it roundly sucks
it sucks even worse now that i got the parts
well the MG Gods are screwing with me just for fun I think
I got the part today and the top trunnion and the threads on the top of the swivel pin are good but the rest is disappointing. I removed the distance tube and bolt from the bottom but the trunnion still didn't move and when I examined it closely I could see the swivel pin was bent preventing the trunnion from turning, but sometimes the swivel pin can be straightened so I went through the effort to straighten it enough to remove the bottom trunnion and then I discovered that the bottom swivel pin threads were badly corroded so its not even worth the effort to try and straighten the swivel pin . time for me to have a beer (which incidently i bought to celebrate tonights accomplishments) and drown out the sorrows and start looking all over again. I badly need a good drivers side swivel pin and trunnions...does anybody have one that I can buy if you do please PM me, thks bob
ok i have determined my origianl trunnions have no play on the good threads so it will be a new swivel pin
clamp steering knuckle in vise and remove nut on the steering arm and then replace it with one of the old castel nuts from the trunnion bolts to protect the treads and give it a good wrap with a hammer
put about 4 mins of O/A heat on the steering knuckle and some good wraps on top of the swivel pin
figure out your movements ahead of time that steering knuckle is really hot.....i am holding it with a pipe over the axle stub
i win
now immediately walk away and go post your success or else you will be touching those damn things and seeing your fingers turn white, so now i think its safe to go back out there
i thought you might find this interesting thisis the trunnion off the bad swivel pin look closely and you can see the bushing is worn right through
and this is taking the bushing out of the one i am going to use
collapsing it on itself
using a press and a socket to get it out
i found my big plates on the bottom of the body work cart
and for the rest of the way i just used the vise and ead blow hammer
Do they still sell these bushings or is this something you press in place and then final ream the inner diameter once it's in place ?
i dont use screwdrivers as chisels but other then that any is fair game for use if its in the garage. the bushings are a clsoe fit and then reamed to size. see below
well I have done something I never did before, I followed Barneys instructions and once again they made the job doable for a home shop. Barney is an MGA guru
I improvised a little since i wasnt sure how it make it all come togehter.
i decided to press the steel bushing in using my press and i made a guide so the bushing would go in straight
i made some reference lines just to make sure the hole didnt get side ways on me.
it worked very well , make sure if you chisel out the bushings to ream the edge if you made any gouges
i then dressed the ends so they were flush with the trunnions
next we follow Barneys instructions and use some tape as a guide
heres the mock up
heres my way to try and not chase a ball bearing around the shop
and it works
so for number 2 i am going to try somethng different with the ball bearing
and i used this the two nuts were tightend to tegether and the bolt would spin. you can see the end that mated to the recess of the reamer
and sucess about 2 hrs of work and the distance tubes fit very nicely.
and to finish the days work....paint the parts and look for cracks in steering arm with dye penetrant and then paint it
red dye
if there was a crack it would show up here in the white
and it gets painted
Lever action shocks in 1958? Wow. I'm pretty sure the last American use of those was in the late 40s.
Despite having several large trucks at my parents' property waiting for restorations, this thread makes me want to restore something little. I'd love to get my hands on a Willys Aero to build a small, practical hot rod. Although, the desire to restore something non-gigantic might explain why I bought a '76 Honda CB550. I've never rebuilt a bike before...
not true, my 50 Buick Sedanette had those on it.
small cars are relatively easy projects in all respects
not saying I'm a skeptic, however, as one who's putting just a little V6 with a couple power adders in a Fiat; I beg to differ
well what can i say...i will rephrase my comments....small cars can be relatively easy projects in all respects unless you put "a little V6 with a couple power adders in a Fiat" :beer:
it all starts with "why don't you just...." :crutches::suspicious:
why nots and what if"s are scary......
back at and glad to wrap up the front end well almost
got the new swivel pin and installed it
feels good to have this wrapped up
then I noticed the rubber water seal popped off...oh well that and the rear axle rebound strap are getting returned for new ones...
replacement parts arrived and are installed, I have to stain the deck this week but after that its back to the car each night. next project will be reinstalling the brake backing plate and the front hubs.
