1958 MGA Coupe
well I agree!!!! but I promised the Mrs. I would finish the back basement "weight room" 15x12 with stud walls and drywall and in Virginia August is the perfect time to do an inside basement project.....read naturally cool. so we got back from vacation last week and I have been out buying 2x4s this week and this weekend I will build the stud walls and then next week start hanging the drywall. The good news is that this is the last thing i could do to this house with the exception of building some "built in cabinets" in the other part of the finished basement . so after this is done, my garage time will quickly come back to me and hopefully it will be a bit cooler.
i am happy to report the wall studs are up, elecetricity is done and 50% of the drywall is up, maybe by the end of september it will be finished and ready for paint....then back to the car...i seem to some how have collected a beer "kegerator" in the garage....so i may look like fred mertz in the near future...
looking forward to October garage time ?? it should be nice and cool by then, when is it getting too old ? November ?? do you have heaters in your garage ?
HEHE...in Rockville Md, just maybe 20 miles north of him, I had a ~125k BTU Gas furnace in my garage.....in about 15 minits it was warm to work, no matter the outside weather....it was GREAT@@!!!!!! Bob will need something similar or DIE....:flash:
I have an 80K BTU in my 2 car nd keep it around 55f
woohoo the painting of the finished drywall has started. october is perfect car weather with an open garage door here. after thanksgiving the heat will get turned on. I have a cieling mounted Dayton 240v electric heater and my garage is so well insulated that it doesnt cost much to keep it warm. i actually think that the beer refrigerator that the keg sits in is so old and inefficient that just keeping the refrig on will keep the place warm. I am thinking I am two weekends away.....heres what i have been working on...i may have slipped over the edge on this one....
thats a 139" diagonal, epson 8350 projector with an onkyo 7.1 HTiB and a pioneer bluray player
hard top believe its been about three monthssince i worked on the car last so i wanted to sart slow with an easy project so i worked on the door hinge plate.
here it is i drilled out the old screws and retapped the holes
heres the retaining plate, nothing really fancy to make this.
lots of one parts............another quick moment in the garage
I took the wire brush to the area
the mock up
i always use the "best ground" set up when i weld
some quick ugly welds
IMG00885-20121028-1123.jpg.
well here is another bite of the elephant and may be the last thing i had to do before i can wrap up this side.
this is the foot well body mount and bolt
this is the template cut out of thin cardboard
this is it laid out on a piece of austin healey 3000 frame i had laying around
some slight persuasion happening
some times things dont fit in the vise to bend when the sides are already bent so i used a piece of flat stock to make the jaws wider
the rough shape
all seams are welded here is the final fitting and welding
to make a nice rounded fit around the bolt hole i used an old steel washer welded to the bottom of the bracket
thks guys
happy Veterans day to everyone thanks for your service, I actually think about all those who came before me and gave me the right to vote when I am in the voting line.
worked some more on the finishing the pass side.
heres the need for the inner panel
heres the template for the inner panel
here I am bending the piece
this is how you get extra leverage with brake
now to fit the big panel and creat the flange< it its upside down in the photo
these are deep C clamps I use on the sheet metal break and are good for many things
you can see the good penetration by the heat discolortation on the panel
My god, that car is a metal swiss cheese and you'll filling all the hole one by one.
This is crazy, in a good way :nuts:
yes lots of swiss cheese but whats good about this project is that there is very litttle out of pocket expense on this, just welding consumables. i needed a project this time that was more time intensive than $$$ intensive. I am still recouping from a wedding this past summer.
well we are getting close to wrapping up this side....
heres the panel fitted in place for welding
I added the supports for under the door posts and painted the inside with cold galvanizing primer over the weld through primer and then 3 coats of rustoleum glossy black
here the interior with gloss black. I will use the mig welder for the welding on this and I will grind away the paint that is exposed prior to welding
heres the test fit before the third coats of paint and I will let dry before I weld it in place.
What a great day yesterday was! I got to go on a road trip with my oldest son, meet fellow NAMGAR member George Kress , work on an MGA and Tour George's car collection. George had been watching my post and realized he had exactly what I needed and offered a donation to the cause of a front shroud, front frame extension, and unbent radiator. I glady accepted this generous offer! Our road trip started at 6:00am yesterday and we reached George's shop by 9:30am. We started the dissassembly process and by 11:20 the three of us had wrangled the front end off the parts car. After we got the Shroud loaded into the Pick up the fun really started and we toured George's extensive car and parts collection and enjoyed every moment of it. About 12:30 we had everything loaded up and headed back home. It was a great Day with my son and it was really enjoyable meeting George and I look forward to seeing him again at one of the NAMGAR car shows....maybe even with my coupe wearing the new front end!
Front frame extension
well i got to work this am on removing the front frame extension from the shroud and worked on it a little bit to bring it back into tip top shape. one of the bumper mounts got bumped when the car got moved into the shop and it broke off when i removed the frame extension and it will get welded back on later this week
here is how i will remove the bolts
i take this stuff serious and i gear up for it and use a full face mask, hearing protection and thick leather gloves, not like these numb nuts on TV who use no protection
here it is removed
all and all its in pretty good shape and way better then my mangled one on the coupe
here are the side extensions hammered back to shape, it didnt take much
working out a little dent, we wont let momma know i am using her potting table...
here it is wire brushed
I printed off of Barneys site the front frame extension dimensions and will use that as a guide to finishing the reworking of the piece
