1958 MGA Coupe
these Ryobi tools are very good, too bad their batteries are not all that great. the newer lithium batteries are better and you can run the old style 18v tools on the newer batteries.
A buddy just bought a 18v sawzall, he takes it to junkyards to cut parts (like front frame rails to get a front clip)...... works fine..... they don't run power to the yard and they also don't allow cutting wheels because of fire hazard.... so that 18v sawzall has taken some abuse LOL
only complaint I have about these are the batteries, I have six that take a charge but last only an hour or so, I also have two lithium batteries that seem to be fine.... I guess after a year or so all these batteries turn into garbage.....
I keep thinking they don't have the battery life to be really effective... can't say that you've convinced me to change my mind. To me they'd be useful, but my truck has a 2500 watt inverter on it, so I can run corded tools when in the field - I'd love to abandon that, but I keep coming back to the problem that almost-cut is exactly the same as not-at-all-cut when it comes to cutting things apart.
if your expectations are a "go to everyday use tool " then pass on it for sure.
the lithium batteries are certainly the way to go. and the saw blade switching mechanism on the reciprocating saw is really very convienent. as i said overall i like the tools on a home shop basis, and taking them to junk yard is a great example
2 more hours tonight wrapping up the door posts, all of the grinding and making the welds look pretty will happen after the bodys off the car
and i added an extra support brace for good measure
are you planning on sandblasting once you're done welding and grinding? Just wondering how much they will charge, maybe $500 ?? I just bought a $400 ALC blaster from Northerntools, sure better to spend $400 on a tool that you can keep for future jobs than $500 or more for labor.... I just sprayed epoxy on my VW rims that I blasted and I have to say, best surface prep ever :1st:
the DC area sucks for vendors that do stuff like that...i have a car trailer so i could create a wheeled dolly and take it some where but i was planning on using a funny looking sanding wheel from eastwood that has little fingers sticking out of it for the outside and then a wire wheel for the inside areas ...if that doesnt do the job i may see about other options. its really not a very big car and i could do it an hour at a time.
hooray for a snow day!!!!
wrapped up some loose ends on the body so all the welding that has to be done before we take the body off the frame is now done. added some corner braces to the bottom of the rear door post, welded the trunk pan in place and welded the inner foot well area piece to the body mount. i am taking an hour or so break then will go out and start on the mechanical aspects of the body removal
test fit of piece
I AM WORN OUT.... little Joe and i spent another 3 hrs tackling the mechanical items that need to be taken care to remove the engine
it helps having a worker...
we are not sure hes going to fit into when its done...
not to hard removing the master cylinder
however the car gots its pound of blood from the bolt that attaches the pedal assembly to the top bracketry....the pedals swiveled on the bushings but the bolt siezed in the steel sleeve
what a PITA....i was able to manhandle it through the opening once the ends were cut off. i could only get the bolt out the sleeve when it was in the vise.
well we were getting set up to for the saturday body removal and then it happened....about 1 hours worth of work...
and this is where we realized we were almost there
yours truly
i accomplish so much more with helpers
and whamo its done
final resting spot
look dad i do fit
and yes I hate trailing arms and those freaking parking brakes....
whos says little kids have to grow up?
well it was too warm out side so i rolled the chassis out and powerwashed it. I had a hot water added to my outside faucet just for moments like this
took the wire brush ,grinder and degreaser to inner fender panels
straighetned out a little bump in the back
and a few clamps and hammering
back to cleaning
and some self etching primer
the work thats left from this point forward really fits well into my 9pm to 10:30 pm schedule after everyone has gone to bed then i go out and play and no one misses me.....once on the 37 ford i got a real second wind and at 3:30 am the i see the wife coming into the garage with a flashlight and cell phone she said she figured i had a heart attack.... well music to a mans ear happened early today...the Mrs and our two daughters went to the mall.....woohoo that means more garage time on the 65* day
so i did the other side and the boot area....after the primer drys for a day or two all the weld seams will get a brushable seam sealer on them.
what the F^%$....working all weekend long and i get this from picking up the grinder with the wire wheel to put it away at the end of the day
well, at least now you can heal at work.... it's amazing how far you've gotten in such a short (relative to if I'd done it) time period.
truly inspiring :thumbs:
work and advil its all a guy needs...
tonight 2.5 hrs were spent on making the aluminum kick panel replacement pieces. i used 22 ga galvanized sheet steel i had laying around this will never deteriorate. as usual Barneys site has all the dimensions to help me piece together the puzzle
Barneys print outs are on the right
the first bend its hard to see
the third bend is what i am working on now and it was the hardest to make for me i had to work onthe jig to set it up
finally flipped it around to get it right
and then the same process on the other side
and yes i do have a lot of clamps and this is one of my favorites....the HF ones dont copmpare
alright that tears it... you've now convinced me to finish the floors in the fiat so I can finish the car.... gosh darn you - I had a good "it'll take me forever" whine going on... maybe if I add some midol to my advil things will go better
Thanks for the attempted intervention, but no, it didn't help. I've been working on the Fiat longer than that.... granted, last night I did get all my transmissions up and into storage so there is light at the end of the tunnel... I can now get the fiat to the lift.
i had the day off today so i chased around some loose ends
IMG]http://img.photobucket.com/albums/v494/bobs77vet/MGA%20Coupe/Body%20work/coupe%20body%20removed%20from%20frame%20on%20saw%20horses/IMG01501-20130315-1028_zps6082cc44.jpg[/IMG]
yes its very much the same
some more nibbles today
the challenge for the day
this is the 4.5" wheel the radius os too big
a used wheel has a better radius
a tab so i can put in the cut out area
the initial weld
now i just keep laying beads onthis to build it up to height
and now i tried new sanding wheel
