68L71
- Joined
- May 13, 2008
- Messages
- 749
The motor was last run a few years ago...apparently it was rebuilt 10 years ago or so. Who knows but it has compression and turns over smoothly...$850 delivered. The guy thought is had a mercury 4" crank but I will have to verify it. I need to move the 289 so I can get the flattie on the stand to work on it. It came with the offy 3x2 you see in the pictures. I will probably run that but the carbs will be pricey and maybe some aluminum heads. I don't really care how fast it is.
The rear is 1939 with 40 something drums...I will run a 1939 spring ground to fit the 33 x-member. I need to take the frame to the blaster soon.
Up front will be 33 split bones with chassis engineering dropped axle and lincoln self energizing brakes. Wheels are 1940 with firestone bias ply black walls. Here I had it sitting on the frame so I could get the steering box mocked up....1948 ford F1 truck box with 1937 ford column and wheel...that is a side steer setup. I had to have a machine shop shorten the steering shaft and put the taper, keyway and threads to mount the wheel. I just put the radiator and grill on to see it.
The interior will be a stock 33 seat leaned back some and no riser. The dash will be stock with vintage SW gauges. I will mount the spedo, tach, oil, and water in the dash insert and the amps and fuel in the center of the dash.
It takes along time to find all the right parts, especially when you use old or original parts and try not to spend a fortune.
