82SR71
Member
Can anyone tell me if a 700r4 from a mid '80s Chevy van V-8 will fit in my 1982 Corvette?
Thanks
Thanks
You will need the tail section, drive & driven gear and speedo drive head off your old tranny.
Well, if he does what Gene says and gets a alter tranny, chances are it's set up for an electric speedo, so he'll have to change all that. If he gets the trans from an F body it's set up for a torque arm that attaches much like the c-beam on a C4 corvette, although they do use a tranny mount (1 bolt only) Where did your tranny come out of?
I got one from an 88 somethingorother, and needed to swap the tail piece, so the mount would fit on the 82 Vette.
I decided to rebuild the original trans. Many problems with tail shaft swap etc.
Had a guy with 26 years experience do the job. Went with the transgo shift kit.
I will not have excessive HP and the original trans lasted 27 years.
Very happy with the results. Shifts are rock solid and even got a 3rd gear scratch.
Thanks to everyone for the good advice.
