Red
I couldn't find any posts using a search, so I'll ask here. My 79 350 engine has long tube headers and power accessories that use individual belts. That said, I'm going to aluminum heads and need to find another way to mount my old pancake style A/C compressor. Currently, it retains the factory bracket that uses a long bolt going through the first header bolt flange in the head. It also has a rod bracket that bolts it to the intake manifold. When I move to aluminum heads, I'd like to mount the compressor without using the exhaust header bolt hole. I considered a serp system from a C-4, but it will absorb too much of my budget. Does anyone have a solution using the old individual belt system? I can weld and have scrap plate steel, but no plan; and I don't want to reinvent something already done. This is where your brain power comes in. Thanks for your thoughts!
